Speaker buzz= new speaker or amp issue?
Old Dec 23, 2014 | 11:07 AM
2012wagon's Avatar
TSX TECH
At volume 14-17 there was a nasty buzz coming. Couldn't figure out where. Already told dealer, while ordering the steering wheela nd window regulator.
This morning played aorund with moving the music front and back and from side to side.
Seems like the "buzz" noise is coming from passenger rear.
I did some searches on here, and lots of this came up in the TL forum as well.
Some said there is a ground problem, some said just replace speaker.
Anyone in the TSX world had this issue, or know what the problem is?
Thank you
Old Dec 24, 2014 | 10:08 AM
fbt's Avatar
fbt
If you can isolate it to a single speaker then that's most likely the problem. There might be a tear in the cone, otherwise substitute the speaker to test.
Old Dec 24, 2014 | 10:38 AM
2012wagon's Avatar
Thank you kindly. Yes I isolated it to right rear passenger. Dealer appt on the 6th.
Appreciate the help
Old Dec 25, 2014 | 10:39 PM
briq456's Avatar
I've had all the speakers replaced 3 times. The subwoofer 1 time. It's a combination of problems, Acura says it's the Speaker, but there was a post a while back where someone did a wave test and they were shocked at all the distortion in the signal going to the speakers. So basically the amp is incredibly cheaply made, the used TONS of equalization to make sub par speakers sound relatively good, considering the amp powering them. So what they will do is replace your speaker with the "upgraded" version. From what I was told it has a different voice coil, but to me they sounded totally different than the original speakers. They seem to have a bass attenuation to them that the original speakers didn't have. But so far, the last set seems to be settling in a bit and they haven't blown as of yet. I'm sure they will though, first time the weather is nice and I have the windows down and don't think to turn the bass down, they are toasted again.
Old Dec 25, 2014 | 11:04 PM
rawger's Avatar
At what volume do you usually listen to your music at? Also connected through iPod, AUX, CD, etc?
Old Dec 25, 2014 | 11:28 PM
briq456's Avatar
usually it's around 15-20, if a songs really good, 27 at the most, but when it's summer and on the highway with the windows down, it can be at max. Point being I had a 1993 Honda Accord with the factory radio and factory speakers and I ran that thing at max with no issues, the "upgraded" ELS system should be able to be played at maximum volume. So it doesn't matter what the source is, what the volume is, or what the bass is set at. It should all be matched. And 90% of the time it's through bluetooth.
Old Dec 25, 2014 | 11:40 PM
rawger's Avatar
Oh yeah, I agree. I was curious since you said you've had the speakers replaced 3x and sub once lol. What is the max volume anyways? 30? I don't think I've gone past 23-25.
Old Dec 25, 2014 | 11:47 PM
briq456's Avatar
40 is the max. And as you go louder, the bass goes lower on it's own, first at 27, then as you go louder treble is also reduced.
Old Dec 26, 2014 | 01:10 AM
2012wagon's Avatar
Thanks guys the info is helpful. The ELS system isn't as good as my standard system in the Lexus Hybrid I just got rid of, which is disappointing, but it is what it is.
I haven't had it higher than 17 yet.
Will keep you posted if dealer says amp 0r speaker.
Old Jan 12, 2015 | 01:41 PM
briq456's Avatar
Any update?
Old Jan 12, 2015 | 01:55 PM
2012wagon's Avatar
Dealer ordered new right side rear speaker. Waiting on it to arrive for install.
Old Jan 12, 2015 | 04:25 PM
briq456's Avatar
yours has to be the only dealership that doesn't stock our speaker.
Old Jan 12, 2015 | 04:29 PM
2012wagon's Avatar
Yeah they didn't.
WHen I took it before X mas, they ordered windshield surround garnish, new steering wheel, new window regulators.
Jan 6/7 they installed all. At which time sound was confirmed to be bad from rear speaker, which they ordered.
Not sure why they don't stock it.
Old Jan 12, 2015 | 05:18 PM
briq456's Avatar
You have a wagon. I wonder if it's a different speaker.
Old Jan 12, 2015 | 05:35 PM
2012wagon's Avatar
I couldn't tell you sir. The TSX wasn't a car I ever wanted, so it wasn't on my radar, so I didn't much pay attention to these things.
Once I get it fixed, I will post the parts number here, so you can guys compare and check it?
Old Feb 11, 2015 | 11:20 AM
2012wagon's Avatar
Update
Took car on a 3100 mile roadtrip south of the border. AFter getting back, car went to dealer on Monday.
Dealer said when he ordered the door speaker, he got a pair instead of one (don't know why).
So he replaced both speakers.
No more buzz (for now).
God my warranty is getting milked on this car!
Old Apr 11, 2015 | 06:33 PM
2012wagon's Avatar
Update:
Buzz came back, new amplifier under warranty.
Can't believe how much warranty stuff has been fixed on this car. Dealer is great, does everything under warrany (even brake fluid flush)
Old Apr 12, 2015 | 04:34 AM
briq456's Avatar
I start to wonder if they maybe updated the amplifier, someone way back when did a test and found there to be huge amounts of distortion from the amp. Which dirty sound easily = fried voice coils. They tried to remedy it with speakers with different voice coils, which, in my opinion, changed the sound quite a bit. I've had every single speaker (except the dash surround speaker) replaced, and the front door speakers have been replaced 3 times now. Keep us updated on how the latest "repair" goes. BTW It's Panasonic who is the weak link with these systems. They made the cheapest amp possible.
Old Apr 12, 2015 | 09:01 AM
2012wagon's Avatar
Thanks for that makes sense
Old Apr 13, 2015 | 10:22 PM
atsx1313's Avatar
oh man i started to hear the vibration from driver side door...
I do hear buzzing when the speaker is on around 15 but i never put that high...
whenever i drive with no music, there is this vibration noise and maybe something is loose... do i need to take this to the dealer?
Old Apr 14, 2015 | 05:43 AM
briq456's Avatar
Are you sure you don't just have something in the door pocket? There shouldn't be any sound from the speaker when it's off.
Old Apr 14, 2015 | 09:02 AM
xtcnrice's Avatar
VTEC just kicked in, yo!
I often hear noise on the passenger side. The culprit is the passenger didn't position the seat belt back properly and it intermittently hits the pillar. Just one theory if some of you are having weird noise issues unrelated to speakers/amps.
Old Apr 14, 2015 | 09:07 AM
briq456's Avatar
LOL I've had the seatbelt noise too, and someone mentioned the sunglasses in the holder rattle too. Worst thing I had happen was to loose a socket into the floor panel in my ITR. It rolled around constantly! I could feel where it was but it was like a maze to get it out. So one day I took to an empty parking lot, and figured out the correct left right accelerate stop combination to get the socket to the opening it apparently went in at. Good times.
Old Apr 14, 2015 | 10:22 AM
xtcnrice's Avatar
Lol I've also lost a clip-nut thing that came with my OEM front underbody spoiler hardware inside the front bumper. I knew exactly where it was in the bumper... but it was near impossible to get out! That was a pita to get out haha
Old Apr 18, 2015 | 07:46 AM
Bchester6's Avatar
Just yank it all out and put some better stuff in!!
Old Apr 18, 2015 | 09:15 AM
briq456's Avatar
Not so easy. Only real option is going line level inputs into different amps. But that's not what I'm looking for. I'm very happy with the sound when the speakers are working. And that its all factory and no aftermarket stuff. I was fine with installing all that stuff when I was in high school. Now having room for stuff in the trunk is helpful. :-)
Old Apr 18, 2015 | 09:16 AM
2012wagon's Avatar
Exactly. Too old to change the stuff, plus my AM radio only doesn't necessitate subs and amps
I just don't want crackling sounds.
Old Apr 19, 2015 | 09:15 AM
Bchester6's Avatar
Stock is cool too but you will undoubtedly fight this issue the duration of vehicle. There really is no solution for bad stock electronic components as they will surely continue to fail since they are just swapping out apples for more bad apples. The stock head unit, if like mine, puts out a balanced signal so this is much better than "line level" or "low level" you just need an amp that accepts "balanced inputs" and you're golden. Oh, you can keep the trunk as all this fits under the cargo tray nicely.
AndrewS
19
Mar 14, 2024 06:59 PM
jpadilla
3G RLX (2013+)
Nov 18, 2017 07:13 PM
handsom-hustla
Nov 13, 2015 05:04 PM
Pegon95
Sep 15, 2015 01:54 PM
iRaw
ILX
Sep 5, 2015 12:10 AM
