Dice ipod problem!!
Old Feb 26, 2009 | 11:07 AM
supe12xj's Avatar
5th Gear
Dice ipod problem!!
Hello,
I installed DICE like a year ago, and it worked fine until now..
All of a sudden, only speaker works with IPOD and i couldnt control my ipod from my headunits.. and none of the title nor album doesnt show on my screen. it only shows "DICE" on my screen.
I cant even control my ipod either if it is connected to my car...
Is there anyone having same problem? or does anyone know how to fix this?
Old Feb 26, 2009 | 02:24 PM
rodneyc77's Avatar
Retired!!! ON TOP!!!
You probably need to do a hard restart of the Dice unit... remove the main harness from the Dice unit for about 2 minutes and then reconnect...
If this doesn't work... then...
The solder points have gotten weak on the circuit board... find someone that's good at soldering and resolder all the points on the DICE unit...
Then you should be good to go...
Old Feb 26, 2009 | 03:50 PM
RC51Ryder's Avatar
Vroooom!!!
What kind of iPod are you using? The only reason I ask is because my iPod touch seems to work better that my 5th gen video with the Dice unit. But yeah, it sounds like solder points.
Old Feb 26, 2009 | 05:24 PM
PeterUbers's Avatar
the solder points have gotten weak on the Dice?? ???
Old Feb 27, 2009 | 12:22 PM
supe12xj's Avatar
5th Gear
Updated IPOD with new firmware.. but it wont work..
i guess it can be solder problem..
do you think resetting the whole battery will fix this? I have a good feeling that it may fix this problem.
man..its gonna be alot of work takin apart for this problem..
Old Mar 2, 2009 | 02:53 PM
supe12xj's Avatar
5th Gear
Disconnected battery for 20+ min, reset the whole thing.
worked like a charm! DICE is back to normal.
4drviper
Apr 23, 2025 07:13 PM
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
