Loc connection
Old Feb 27, 2009 | 05:48 PM
108tls's Avatar
Loc connection
need to find out what speaker wire or wire color coding from the factory radio to the factory amp. is.
i plan on tapping the loc between those two, right after the factory deck, before the factory amplifier.
thanks in advance for any help or inputs.
Old Feb 27, 2009 | 06:17 PM
csmeance's Avatar
If you do that you will need a line driver to raise the signal to an acceptable level, the high/low is the complete opposite of what you need to do.
Old Feb 27, 2009 | 06:31 PM
CSWBiggs's Avatar
you're on track for failure...
LOC's attach to these wires post amplifier!! If you feel the need to go before the amplifier than you can just modify some RCA's and solder them directly. And I have the appropriate wiring diagrams for those as well
left front + LIGHT GREEN
left front - Purple
Right Front + Blue
Right Front - RED
Left Rear + Brown/White
Left Rear - Red/Yellow
Right Rear + Red/Blue
Right Rear - Yellow
Subwoofer + yellow/Black
Subwoofer - Light Green/red
Center + Brown
Center - White/Light Green
-Jason
Old Feb 28, 2009 | 02:35 AM
greco9885's Avatar
just attach it to the wire going to the factory sub, you will save your self SO much time and effort.
also, since i think you have a type-s you will need to do this:
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/i-163-amp-sub-installed-08-tl-s-amp-not-getting-signal-when-doors-shut-700991/
Old Mar 2, 2009 | 02:58 PM
108tls's Avatar
thanks for the quick replies guys, i've rethink this a little and probably will go with audio control line driver from speaker input then rac output to processor.
knight rider
Mar 4, 2016 08:59 AM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
ValdezQ26
Oct 1, 2015 04:48 PM
