Diagnostics Menu
Old Apr 27, 2007 | 02:10 PM
krravi's Avatar
Question Diagnostics Menu
I just went through the Diagnostics menu and there were a ton of options. Though i managed to calibrate the screen and what not, i am not sure about the rest of the options.
Does anyone have a breakdown of what those options mean and what values need to be set ?
Old Apr 28, 2007 | 07:21 AM
gt1's Avatar
gt1
` . ' . SUV haterrr
They need to be left alone.
Old Apr 28, 2007 | 07:42 AM
Alligator's Avatar
Waiting for delivery
How did you get this? I need to calibrate my screen.
Old Apr 28, 2007 | 10:34 AM
krravi's Avatar
I understand that its not for us. But i was just curious as to what they meant. Especially "Tire Adjustment".
There are two options there called "F-CAN" and"B-CAN". One of them is showing "Active error". I was wondering if anyone knew what that meant.
Old Apr 28, 2007 | 10:36 AM
krravi's Avatar
Press 'Menu' + 'Guide' + 'Cancel' at the same time and hold it for a couple seconds and you will get a Diagnostics Menu.
Once you are there, you will see "Functional Setup". And i believe adjusting your screen is there. Good thing is i was able to adjust the sensitivity of the mic in the car too.
Old Apr 28, 2007 | 12:21 PM
krravi's Avatar
I am sorry its not "Functional Setup". You will see something like "Navi Screen". There you can adjust your raster, color balance etc. Just like adjusting a TV. Most of the default setup is correct. You hardly need to adjust anything. There is also a screen to calibrate your touch sensitive screen.
Old May 12, 2007 | 10:06 PM
krravi's Avatar
So anybody with a 05 Acura check the diagnostics and tell me if they have "Active error" display in "F-CAN" ?
Old May 14, 2007 | 12:06 AM
gt1's Avatar
gt1
` . ' . SUV haterrr
I guess that "Tire adjustment" is for calibration of speed with different tires. It is done automatically by comparing data from GPS and sped sensor.
Diagnostic will dispay an error (don't remember where exactly) if your key is in ACC rather than in ON position.
I also was exited about possibility to tinker with car settings, but there is nothing you can change to the better in diagnostic menu.
Old May 15, 2007 | 10:15 PM
krravi's Avatar
The only thing you can adjust is the screen, the rest are probably not much help.
BTW, did you check the status of "F-CAN" and "B-CAN" ?
I think those are communication buses in the cars electronics. But i am curious as to what others cars show.
4drviper
Apr 23, 2025 07:13 PM
ValdezQ26
Oct 1, 2015 04:48 PM
hashbrown
Sep 29, 2015 12:13 PM
dirleton
Sep 25, 2015 12:25 AM
SpraykwoN
ILX
Sep 16, 2015 09:24 PM
