Custom trunk setup? Custom sounds? PICS??
Anyone have any pics of their ride or anyone elses ride with custom trunk set up. Trying to get good ideas for my trunk
Currently have a JL W6 13.5 and two amps, so ill be getting a custom box built and have room for my spare tire also while mounting my amps nicely.
Trying to get a nice car show set up.
The following 6 users liked this post by DiamondJoeQuimby:
BlueAc (03-29-2013),
daciss (06-13-2013),
Davidsternmustdie (06-19-2013),
KJ TL-S (03-28-2013),
maska (06-11-2013),
and 1 others liked this post.
h
That is BADASS! Nicely done man. Did this yourself or a shop?
Do you know what type of wood they used throughout the trunk? Not including the box..
Are those W7?
Are those W7?
Codename Duchess
5/6 of the box is 3/4" MDF. Front panel is 3/4" acrylic. There is no other wood used in the entire car, including amp rack, kick panels, or trim panels. The trunk trim panels (including the floor) are all made from fiberglass and then carpeted or vinyl-ed. The side panels in the trunk are re-carpeted OEM ones. All the equipment racks are either aluminum or steel.
They are 8" W7-AEs down firing. The amps are (3) JL HD600/4s.
Thanks.
Yes. I did it all myself, but I'm a manager for a shop. I have about 15 yrs in the industry.
Thanks.
Thanks.
Codename Duchess
The carpet as actually just a standard carpet I got from a local upholstery supply place. The trick is, I re-covered all of the oem panels that I used so it matched.
The copper is actually copper tube (due to more surface area than solid pipe) that I made a jig for and bent to the shape I needed. I then hand polished them to get them shiny and put a gloss clearcoat over them save the last .5" on either end. Didn't want to go to all the trouble and then have them tarnish.
Thanks for all the positive feedback guys. I wanted it to be something understated yet very custom. I really tried to pay attention to design cues form inside the car and carry them to the trunk. The red rings around the subs are painted acrylic and hide the mounting holes for the subs. The idea was to mimic the three red rings that encircle the gauges on the Type-S. And the "Acura" panel is perforated gray vinyl surrounded by black vinyl to mimic the seats. I tried to make it as practical and serviceable as possible.
That is a BADASS Setup/design!! Nice Work
Very nice! Love the custom connections to the subs
Can I ask how you wrapped the factory side pieces where it comes out really far for the trunk hinge when it closes? Did you do it all one piece or 2 pieces? I can't imagine carpet stretching that much to do it in 1 piece.
Codename Duchess
I did them both in 1 piece. The driver's side sucked to do. Behind the panel on the box though, I cut most of the stock material away so I didn't have to deal with the complex curve over the wheel well. On the passenger's side I had cut a majority of it away for the amp rack so that one wasn't bad. I just started in the deepest part of the well and started working toward the edges. The carpet I used was un-backed and stretched really well.
after seeing that im ashamed to show the set up i had in my tl.
i am working on a new setup. im trying to get my hands on a 12w7 right now. i built the box kinda fast and never finished the beauty panels, due to the fact i was planing on upgrading. but here is my little setup. also this is my first box that i ever built. it was a learning experience for sure. im not use to working with wood. i work in a machine shop with metal and cnc machines. i was in a new world to say the lest.
i had everything but the kenwood amps from my last car. i have recently bought a jl hd900/5 im just waiting to put it in till i get my hands on a 12w7.
teeeejaay (06-08-2013)
@rhdstinky, nice setup bro. what gauge wire are you using on the jl amp?..also do you have all three amps individually going to the battery or do you have like a 0 gauge wire going to a splitter?...also, are you going to be selling that jl amp soon and how do you like it?
bluetl04 (04-10-2013)
Nice feedback guys, if anyone has any other pics please post! Dont be discouraged Im willing to see everyones set up... Getting ready for a show in aug want to have a new set up.
Tweeters and Midbass are install and the MB will come out of the inside of the door. I'll be doing a sealed box or a better aimed baffle into the cabin for the MB. Midrange is either going in the A-Pillars or Kicks. My wish is to put them in the dash firing back into the cabin, But spending another 3g isn't on my list for just the MR.
Nice setups, I bought my tl a little over a month ago, I'm currently working on a enclosure for my 2 Sundown woofers not sure wether to do bandpass or just go with a ported setup, running 2 Rockford amps, 2 Sundown Audio SA8V2D4's, Infinity Kappa Components, and a Pioneer AVH-X5500BHS which was not a very fun install but well worth it
^^ pics of your HU install please.
mada51589
05-03-2022 08:54 PM
TLDude876
12-28-2016 03:18 PM
handsom-hustla
11-13-2015 05:04 PM
DiamondJoeQuimby
09-10-2015 11:40 AM
