Constant Radio Static HELP!!!!!
Old Feb 14, 2016 | 12:39 PM
KayBee's Avatar
Post Constant Radio Static HELP!!!!!
I have an 04 Acura TL. I recently installed aftermarket speakers all around, amp, and sub. I kept the factory radio and I didn't bypass the stock amp as well. Whenever I turn on the car, with the radio off, there is low-pitched static present. When I turn the radio on the static becomes greater and is constantly present and can only be 'drowned out' when the volume is high. Also, whenever I rev my engine, it's like the static is in sync with the revs. I've looking around and I've read that it could possibly be the factory amp thats causing the static or I may be in need of an aftermarket radio. Truthfully, I would like to keep the factory radio is possible, but if that's the source of the static then I has to be done. Thanks!!!!
gavriil
Apr 1, 2026 12:45 PM
Aaphree
68
Jan 7, 2024 06:56 PM
STL acura
May 7, 2017 03:24 PM
07mdxID
1/2G MDX (2001-2013)
Feb 5, 2016 03:04 PM
cobra10363
Jan 22, 2016 02:28 PM
