cheapest way for AUX on 04 TL
Old Feb 4, 2010 | 02:35 PM
mcmguti's Avatar
TL = True Love
i have an iphone but dont need the ipod cable, just an AUX cable, in case someone else wants to hook up their mp3 player.
ive researched all the different ipod integration kits, they cost around $130+
i just want to know if there is a poor mans way to get an aux cable integrated with radio by bypassing XM(which i dont use)
Old Feb 4, 2010 | 06:31 PM
fade2blk's Avatar
there sure is a away, I have done it. and it works great.
ok ok, you want to know how?
you will need 4 bosh relays, a switch, and some wire.
your answer can be found here 3G TL Audio & Electronics FAQ and look for this thread.
It is also possible to splice into the factory wires to add an aux input.
your answer is there.... all you have to do is just look.
Old Feb 6, 2010 | 12:44 AM
mcmguti's Avatar
TL = True Love
thanks didnt see that
Old Feb 6, 2010 | 09:27 AM
DMZ's Avatar
DMZ
Head a da Family
The easiest way is to get a cassette adapter from Radio Shack. Looks like a cassette with a wire coming out that has a headset plug on the end.
Sometimes this inexpensive solution works great and sometimes it doesn't. You might want to try it before going through all that splicing, etc..
Old Feb 6, 2010 | 07:25 PM
imj0257's Avatar
Q('.')=O
^ ya but cassette adapters and FM transmitters have shit sound quality compared to a real aux input, such as the 'Isimple' <-- I'd check that out, its like $140-$190 and is stereo system quality sound.
Old Feb 6, 2010 | 09:53 PM
Joe Foe from Buffalo's Avatar
You could cut the wires to the cassette head and use that as a input with head phone sound level audio.
Old Feb 6, 2010 | 10:15 PM
fade2blk's Avatar
so let me capture this, you are saying. take the radio completly out. dissamble tape deck. get chematic for inputs and use that?
seems like one way to destroy it.
cassette adapter sounds way easier then that. drawback sound quality.
Old Feb 7, 2010 | 09:16 PM
SHaFT7's Avatar
I did the diy relay / switch thing.
works great, just that the volume level is a fair bit lower than all other inputs. perhaps an inline amp is needed....
Old Feb 9, 2010 | 01:41 AM
JohnnyGlock's Avatar
4th Gear
I followed a thread that was posted here a while back and hijacked my XM audio channels, didn't even bother with relays (since I don't use XM), a quick soldering job, and I had clean line-out from my iPod and iPhone 3G! Super simple, super cheap.
Old Feb 9, 2010 | 05:43 AM
gatrhumpy's Avatar
Chapter Leader
(Northeast Florida)
Are you looking for cheap? Because the cheapest way would be the cassette adapter. Only downside is the quality of the sound.
Probably the next cheapest way would then be the switches with the relay, but that would require a lot of electrical work, and, if you're not familiar with it, would ruin your sound system.
The best way would probably be the Y-adapter with the Aux-input from soundgate or something like that. It plugs into the back of the harness where the XM radio is and allows you to listen to any AUX source you want. It does not replace your XM (unless you want it to), just adds to it.
Old Feb 10, 2010 | 09:22 AM
mcmguti's Avatar
TL = True Love
so basically look at XM wires and just get the L and R signals to an 8mm jack with y adapter? i dont mind losing the XM I never use it, i have digital radio on my iphone so why pay?
4drviper
Apr 23, 2025 07:13 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
ValdezQ26
Oct 1, 2015 04:48 PM
navtool.com
Sep 25, 2015 05:15 PM
