Bump stop screw
Old Apr 21, 2013 | 05:57 PM
cnwahlheim's Avatar
Bump stop screw
I just installed Hushmat in my driver's side door, and when removing the door panel I had to pull it over the bump stop screw because it just kept spinning when I tried to unscrew it. Now I cannot figure out how to get the door panel back over the screw so that I can put the bump stop back on.
Any suggestions?
Old Apr 21, 2013 | 06:02 PM
paperboy42190's Avatar
pliers....a lot of ppl have this problem
Old Apr 21, 2013 | 06:30 PM
cnwahlheim's Avatar
^ How does one use the pliers? Needlenose?
Old Apr 21, 2013 | 07:24 PM
Fulani has a TL's Avatar
Use pliers to apply a pulling pressure and then you can unscrew the screw while pulling on the stop. Make sense?
Old Apr 21, 2013 | 07:37 PM
cnwahlheim's Avatar
Yes, thanks!
Old Apr 21, 2013 | 08:09 PM
abirvalg's Avatar
just order a new one, they have a square base that keeps it from turning
worth it, not to scratch the paint with pliers
Old Apr 21, 2013 | 08:30 PM
cnwahlheim's Avatar
Pliers worked perfect. Thanks again!
Old Oct 18, 2013 | 08:22 PM
haycarajo's Avatar
3rd Gear
I missing one of the rubber bump stops on the front door panel, where can I buy them????
THANKS
MrHeeltoe
20
Feb 23, 2023 01:54 PM
emailnatec
29
Sep 28, 2018 04:27 PM
spoiler900
Oct 10, 2015 06:48 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
