Best buy install fail
Old Mar 5, 2010 | 05:24 PM
Magikmanzx's Avatar
Just got my car back from best buy. I have a 07 TLS. I had them install and isimple and apparently it wasn't simple. So far, the iPod and iPhone doesn't work with it. And! My dash control buttons don't work for my navi ie menu, setup, audio buttons. And my hfl doesn't work on my steering wheel. WTF.
Old Mar 5, 2010 | 05:44 PM
Derk's K24's Avatar
is in Honda heaven
Unfortunately your first mistake was taking it to best buy. An auctual audio would've been your best bet if one was available. Some Best Buy's have qualified installers but for the most part they all lack the qualifications for simples installations.
Old Mar 5, 2010 | 08:04 PM
Eiswritsat's Avatar
TL owner
had the same thing happen with my car after i installed my isimple and found out the unit was jacked up and was causing the problem. unplugged it and everything worked fine...so before u blame the installation check the unit, make sure the firmware is up to date then go from there.
Old Mar 5, 2010 | 08:05 PM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
Sorry to hear. But, go to a stereo shop if you can.
Old Mar 5, 2010 | 08:41 PM
KN_TL's Avatar
Those big box stores are the worst installers. Blaming them is still valid. How do you release something where the prime function doesn't work (Iphone Ipod).
Hopefully you'll be able to get this worked out. Good Luck!
Old Mar 6, 2010 | 09:00 PM
Styx17's Avatar
blaming best buy isnt actually valid because if you didnt do the firmware update to the unit then it wont actually work with the iPhone, also if you didn't choose the right cable when you gave it to them to install it wont work either. So before you blame the installers make sure you gave them everything that you wanted installed, because mine didnt work with my iPhone either until the right cable was installed.
Old Mar 7, 2010 | 12:55 AM
Magikmanzx's Avatar
Ive tried 2 different iphones and 3 different ipods with the latest firmware. So im unsure what you mean by updating the firmware. also, im unsure which cable is the "right cable." could you explain? i bought the isimple product.... handed it over to the installer and let them do their work. i didnt know i had to babysit them.
Old Mar 7, 2010 | 06:28 PM
KN_TL's Avatar
That's BS. If you pay to get it installed, then it should work when you leave the bay. Who buy's something like this without knowing what product they want to interface it with?
I would expect this if it were a self install.
Old Mar 7, 2010 | 09:42 PM
thait's Avatar
I need a car in
when they said firmware, i think they were refering to the isimple firmware not the iphone firmware.
Old Mar 7, 2010 | 10:12 PM
Magikmanzx's Avatar
how do i do that?
Old Mar 7, 2010 | 11:23 PM
Magikmanzx's Avatar
ok ive gathered that i need harness #PGHHD2C for my 07 TL-S cuz it has Navtraffic. im hoping buying this harness will get it to work.
Old Mar 7, 2010 | 11:34 PM
erick3's Avatar
bummer...! keep us posted!
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
james357
Feb 13, 2016 02:37 PM
EvilVirus
Dec 10, 2015 07:38 PM
wusty23jd
Sep 24, 2015 11:41 AM
gqdabien
Sep 8, 2015 11:41 PM
