Back up camera
Old Sep 2, 2005 | 12:32 AM
ryutl32's Avatar
7th Gear
Smile Back up camera
How come there are not more pics of the backup camera on this forum?
I need help please!
Which is better?
Avelectronics or Tvandnav2go?
When you install the back up camera do you have to drill holes in the car?
Please give me you thoughts and feed back.
Thank you in advance………………..
Old Sep 2, 2005 | 01:00 AM
NFLblitze1's Avatar
Youse Gots Sacked
your talking about the navigation conversion module. there isn't much talk about backup cameras on the forum although a back up camera would be great especially with all the blindspots in the TL...there are a few threads on the forum if you search for Backup Camera ull find a few things.. good luck
Old Sep 2, 2005 | 05:10 PM
Greg-ster's Avatar
The '03-04 MDX had an optional backup cam that interfaced with the navi. They also had the same navi ECU as the TL has now.
I dont know if the MDX had a HFL though...
Old Sep 2, 2005 | 06:33 PM
crazymjb's Avatar
So you are saying it takes the place of the HFL cable? When you go into the navi system diagnostic it shows the ECU being a seperate module from the HFL. I will take a pic if you really want one. I think my idea is the best for installing a rearview camera. It requires:
1. A Vsokolov unit
2. Licence plate camera
3. Power source(possibly add a circuit, but I think there are power sources in the trunk that are tapable since the camera draws virtually no power)
4. A 12 volt relay
5. Some wire
How to:
1. Install the vsokolov unit(how you power that and the camera is up to you)
2. Insert the relay somewhere in line from the reverse lights to the shifter switch
3. Clip the switch on the Vsokolov unit and connect the leads the two poles on the relay
4. Run the wires for the camera and connect it to the Vsokolov unit
5. Putting the car in reverse and look at what you are about to hit on your navi
Just gonna take a second to wave myself of all liability. You screw up, aint my fault. Ahh, thats better. Also, I haven't done this(yet), but with my vast amount of knowledge I assume this should work.
Old Oct 21, 2005 | 01:59 PM
silver05tl's Avatar
sounds like it should work
Old Oct 21, 2005 | 02:33 PM
rbf351's Avatar
Registered User
1. A Vsokolov unit
4. A 12 volt relay
5. Some wire
How to:
if you don't want to use a relay you can use the group from the indicator light on the shifter plate, and run that to the camera ground, so when you switch into reverse it will turn on
rockyboy
Aug 4, 2024 10:35 AM
Soul_Deamon
Nov 13, 2018 04:44 PM
bymotion
Nov 18, 2015 11:28 AM
Soul_Deamon
4G TL Problems & Fixes
Nov 2, 2015 04:32 PM
2015TLX
Sep 11, 2015 02:56 PM
