Amplifier
Old Dec 18, 2010 | 10:11 PM
mahfuzzz's Avatar
Amplifier
arite guys so my speakers sounded messed up and had no idea what was going on so i took my car to best buy and they said my speakers were fine and then they checked the stock amp and realized that the amp was messed up and i need to replace it...
it costs 400+ at acura...helpppp guys dnt kno what to do now...
Old Dec 18, 2010 | 10:16 PM
SpiderX1016's Avatar
If your sure the amplifier is messed up, it's $100 here.
http://cgi.ebay.com/ebaymotors/04-05...e#ht_983wt_939
You can check out the Black Market here or your local junkyard.
Old Dec 21, 2010 | 10:37 PM
niebur3's Avatar
I am just curious, what problems are you experiencing with your amp/speakers?
Old Dec 23, 2011 | 08:11 PM
jxy234's Avatar
In my '05 TL I am getting a buzzing engine noise thru my speakers when the engine is on....but not when key is just in the Acessories mode. Dealer determined it was the Amplifier (39186-SEP-A01) and they wanted $621 installed or $481 for part only. I found new OEM online for $302...still expensive but afraid of buying used at this point as I already paid dealer $140 for diagnosis. UGH.
Old Dec 24, 2011 | 02:06 AM
I hate cars's Avatar
I think for that price you should go aftermarket.
If you're really set on a stock amp I'll sell you mine cheap. If you aren't happy with it I'll give you a refund and pay the shipping. Its getting thrown away if it doesn't go to someone.
Old Dec 27, 2011 | 09:48 AM
MOS805's Avatar
Got The Midas Touch
Definitely agree with IHC aftermarket is the way to go especially now that your stock amplifier is dying. The added headroom and clarity from aftermarket is definitely worth it, plus it opens the doors for even greater sound later with aftermarket speakers.
Old Dec 27, 2011 | 11:18 AM
Deerole's Avatar
Originally Posted by mos805
definitely agree with ihc aftermarket is the way to go especially now that your stock amplifier is dying. The added headroom and clarity from aftermarket is definitely worth it, plus it opens the doors for even greater sound later with aftermarket speakers.
+1
Old Dec 27, 2011 | 12:19 PM
JD TL-S's Avatar
WHERE can I find a true 5 channel amp, Example= 5x75 watts rms. I dont need a sub amp. I just want a clean 5 channel amp to replace the low powered OEM amp. Then replace the speakers afterwards.
I found an Alpine 5 channel amp but it only works with an Alpine head unit.
In this DIGITAL AGE I didnt think it would be SO HARD to find a 5 channel amp that has the same WATTS RMS times 5. EVERYTHING I find is a 4 channel for regular 2 channel stereo and a sub amp. 4x___ + 1X___
Old Dec 27, 2011 | 12:54 PM
There's just no demand for that configuration. I've never seen an amp with 5 equally powered channels. Your best bet is a 6 channel running the whole show and sell your current sub amp or run the 6 channel for your remaining 5 channels and leave one unused.
The only other alternative is to try and find a 5 channel 4+1 amp with a full range sub channel and turn the gain way down on the sub channel. The best I can find is the JL HD with a sub channel that goes up to 10khz.
Some of the class AB amps might have a full range sub channel but it's getting harder and harder to find one of these. Most of the ones I've found are AB on the mid/highs and class D on the sub.
Old Dec 27, 2011 | 01:52 PM
MOS805's Avatar
Got The Midas Touch
Imho don't go 5 channel route, I did that and I really regret it I wish I would have done seperate components (4 channel or 2 channel depending if your running rears) and a mono sub amplifier. The only 5 channels that have really caught my interest is the JL HD900/5 but it costs quite a bit of change (ask IHC) and the Hifonics Zeus ZXi60.4 + 1K but I have heard that newer Hifonics don't do rated power so unsure if it really is worth it. Theres probably more out there that are good but those are just the two that I looked at that seemed worthwhile to me.
NVM Im sorry failed to see the part where you said equal wattage oops.
4drviper
Apr 23, 2025 07:13 PM
Feb 25, 2020 09:57 AM
tpraka300
3G MDX (2014-2020)
57
Dec 10, 2018 02:17 AM
Soul_Deamon
Nov 13, 2018 04:44 PM
spdy0001
Sep 30, 2003 12:12 PM
