Aftermarket Amp Placement
Old May 18, 2005 | 11:51 AM
PriMo718's Avatar
Those of you with aftermarket amps, where do you mount them? I do not want to mount it to the back of the seats. Is it possible to mount it to the bottom of the rear deck? Or if we have enough room to mount behind trunk panels?
Old May 18, 2005 | 04:29 PM
SSM6MTNAVI's Avatar
Weather Watcher
In my previous 00 Accord I found it very easy to mount the amp behind the seats. But the material behind the TL seats is too soft to support an amp mounted on them. So I ended up mounting mine behind the sub box and have been very happy with it there.
Old May 19, 2005 | 11:17 AM
bklynpanman's Avatar
321 whp SAE
installed mine under the passenger and drivers seats...
Old May 20, 2005 | 09:29 AM
PriMo718's Avatar
when placing the amps under the seats... does it get in the way of any of the electronics under the seat? in the way of the floor mats?
Did you have to remove the seats in order to bolt down the amps?
Old May 20, 2005 | 09:33 AM
321 whp SAE
you really don't need to remove the seats.. you can take off the 4 bolts and tilt it back. doesn't get in the way of anything under the seat.. you don't need to bolt them down.. i used a couple pieces of velcro and it stays put.. the rear end of the amp sits on part of the floor mat.
4drviper
Apr 23, 2025 07:13 PM
Jul 16, 2017 07:33 AM
vpasla1
Sep 17, 2016 07:24 PM
InFaMouSLink
Oct 30, 2015 09:43 AM
