Adding more power to stock speakers?
Military Enforcer
Is there an easy way to add more juice to our stock speakers? I don't exactly want to change out the speakers, but we all know that the system can lack in the sound dept. What's the easiest way to get more sound through this thing?
TL Enthusiast
Any audiophile or audio enthusiast will tell you, The weakest link of an audio system is by far its sound drivers. replacing your speakers will make your setup sound a lot better. it's also a lot more easier than running wires for an amp, and creating a speaker-level input signal for your amp. get speakers!!!!!! you might lose a little "factory bass" by getting new speakers, but the clarity difference will surpass that greatly.
Military Enforcer
I don't think you can just go and add aftermarket speakers to our stock amp, it doesn't have enough wattage, plus there aren't that many 2 ohm speakers running around that can work on low watts either so there lies a problem unless anyone knows of any...
Use deadening
https://acurazine.com/forums/ramblings-12/firefox-questions-131453/
Originally Posted by aznbo187
Put on some of the remaining sound deadning around the front speakers, and also the foam matt on the door panels. Wow what a night and day difference. Virtually no rattles from any song. Huge midbass increase, and also a big increase in loudness overall. Treble and sharpness has also increased a whole lot.
Only problem i had was that I placed too much foam matt onto the panels and couldnt fit the panel back onto the door, so I had to remove a layer or two and try again.
Deadening is a really good first step that retains the factory tuned system and increases loudness by keeping the stereo sound in the car and road noise out(which BTW also makes the cabin more quiet and talking on the HFL better).
I ended up getting a custom system since I like it really loud and clean but will likely go with deadening as the first on my next car.
TL Enthusiast
Originally Posted by bTwix
True, but then be prepared to get new amps to drive the new speakers cleanly, bypass the factory amp, EQ and/or line drivers to the amps, car alarm to protect it all, and you'll want to deaden it all anyways.
True, stock dampening sucks. getting better stuff will help. I guess my point is the best way to do it is to just not use anything stock, but if you must, run just the stock radio with a JL cleansweep and then aftermarket amps and speakers. but that's a lot of money. at least a couple thousand. good point about sound dampening.
TL Enthusiast
what's good cheap sound dampening stuff?
I'm sure a company online has cheap stuff......but if you buy bulk Dynamat it's not that expensive. it'll make your speakers sound better in every aspect. do it!
-----Like, the big package of dynamat for like 150 that's 3 big sheets or whatever.
Here's something else your can try. I haven't used it but it is high recommended on other online car audio forums. A 15" x 50' roll (62.5 sqft) for only $119.00
http://www.raamaudio.com/
jjh1234 - I think you were talking about Owens Corning Weatherguard. Its asphault based and sticky as hell. You can pick it up in 50 and 100lb rolls at lowes in the roofing section.
Joseph Stansbury
34
12-04-2015 01:57 PM
sockr1
10-01-2015 01:31 AM
Pegon95
09-15-2015 01:54 PM
