AC3 to DVD-A
Old Nov 20, 2005 | 11:28 PM
sebounet2005's Avatar
TL 2012 SH-AWD TECH/UMBER
AC3 to DVD-A
Is there a way to convert an audio track from a DVD audio video to a DVD Audio for our TL. ?
I think the track is an AC3 or may be something else
Old Nov 21, 2005 | 01:31 AM
Toronto-TL's Avatar
I use foobar2000 which works great.
Old Nov 21, 2005 | 03:01 PM
MINTCENT's Avatar
https://acurazine.com/forums/ramblings-12/want-live-nyc-itll-cost-you-126570/
Old Nov 21, 2005 | 04:48 PM
thanks for the links
because i did a search with AC3 as a keyword and it's too short for the research motor.
Old Nov 21, 2005 | 06:00 PM
Adobeman's Avatar
The DVD-A Script Guy
Check this thread out as well. https://acurazine.com/forums/ramblings-12/i-need-some-living-situation-advice-123681/
It discusses a well received app for burning DVD-A and also has discussions about how people are converting DVD-V audio (DD5.1,) to DVD-A. Many are using DVD Audio Extractor.
Old Nov 21, 2005 | 11:00 PM
Thanks again this method is simple, i was a bit lost with the other methods
Old Nov 22, 2005 | 08:23 PM
Adobeman or someone else can told me if i need a 5.1 card in my computer to convert Audio from a DVD VIDEO to wqv
Actually using DVD audio extractor and it seems that even if i choose AC3 6 channel, the different channel have about the same thing except that some have some kind of echoes. Channel 4 nothing for example
To sum up
Does the process of decoding a DVD VIDEO to wav use the sound card ?
thank you
Old Nov 22, 2005 | 11:53 PM
Bplayer's Avatar
Decoding does not require a 5.1 card, in fact I doubt that it even needs a sound card in the PC. The extract and burn worked fine for the two DVD-V's that I tried, even at 16bit. Even though you selected the AC3 6Ch make sure that you select 5.1 for the output rather than stereo.
What are you using to playback and to compare each channel?
ps. Should'nt you avitar be rotated? It looks like it is heading down for a crash and burn. Nice pic though.
Old Nov 23, 2005 | 07:16 AM
I read each file with Windows media player 10, with no problem
May be because it's David gilmour in concert there's not a lot of difference between separate channel.
As for my avatar i think it was a question of size, i'm going to check this
acuralvr1
67
May 26, 2007 09:35 PM
skidrow
Apr 11, 2005 02:04 AM
srika
Technology
31
Jul 3, 2004 12:22 AM
JonDeutsch
Mar 13, 2004 11:32 PM
gregory28
Nov 19, 2003 09:49 AM
