2008 TL - Fuse Names
Old 03-19-2008, 06:58 AM
DMorgen's Avatar
Can anybody point me to a listing of the interior fuse box slots, which explains what the abbreviations in the manual mean, for a 2008 TL?
I'm trying to finally find a slot that works for my radar detector installation (problems described in another thread).
Thanks!
Dave
Old 03-20-2008, 07:26 AM
DMorgen's Avatar
Question
Does anybody know what these fuses control?:
DBW
LAF
IG1 OPDS
IG1 Wiper
IG1 ACG
TPMS
Meter
Are any of these suitable for use with an add-a-circuit to power a radar detector?
Thanks.
Dave
Old 03-20-2008, 10:15 AM
Registered User
rbf351's Avatar
https://techinfo.honda.com/rjanisis/.../BEQ0808OM.pdf is the link to the 08 TL manual
not sure if this helps but here is from the 04-05 service manual
Old 03-20-2008, 11:42 AM
DMorgen's Avatar
That's what I need! Thanks!
I just checked the online manual ... it has the same meaningless (to me) abbreviations as the hardcopy.
I spot checked the descriptions in yours ... they either match, or are compatible with the abbreviations. On a quick look I have some possibilities ...
3 Yours says not used, Daytime Running Light, which I presumably don't have in the US, although there's a fuse in the slot. I'll have to test to see if it's switched.
9 Front & Rear Accessory Power Sockets. I'll have to test to see if it's switched.
11 Windshield Wiper Motor.
12 TPMS. Yours says unused. I have no idea what TPMS stands for, so I'll leave that one alone unless I found out what it is.
Dave
Old 03-20-2008, 12:32 PM
Full of water...
blkaspec's Avatar
Dave
TPMS = Tire Pressure Monitoring Systen
Old 03-27-2008, 11:06 AM
DMorgen's Avatar
It took a long time to get there, but I finally have the radar detector installed, working, switched & the fuse cover on!
My most recent discoveries:
Fuse #9 (Accessory Sockets): Not switched. But this is strange because later I tried one of the sockets & it was switched. But I'm not going to worry about this!
Fuse #3 (Daylight Running Lights): Not switched. It turns out this US car does actually have DRLs! And they are switched. Once again the mystery will remain.
Fuse #11 (Windshield Wiper Motor): It works!!! This may be the largest fuse in this fuse box (30a). But it works & I'm happy!. There was a tight fit with the add-a-circuit & the panel (which I refused to take off again!), but I managed it with the appropriate twisting & turning of the add-a-circuit. Of course just when I thought I had finished the job, I noticed I had detached the panel in the area closest to the door during all those contortions, but I managed to figure out how it attached & attached it.
This job certainly took longer than I had expected!
Thanks for all help.
Dave
Acura604
20
08-05-2017 12:55 AM
08_UA7_Gr33k
02-11-2016 02:17 PM
adrian_s2k
1G RDX (2007-2012)
23
01-12-2016 04:25 PM
ripit
09-26-2015 06:19 PM
ROSSARONIE
09-22-2015 11:46 AM
Quick Reply: 2008 TL - Fuse Names
