07 type s sub/amp loc
Old Aug 20, 2010 | 02:27 PM
Mr3lite's Avatar
Unhappy 07 type s sub/amp loc
So I have read the forums for about forever but I am still unable to get everything right.
Power wire- ran on driver side
Rem wire- tapped into fuse #32 using add-a-fuse
Ground wire- grounded in trunk above spare, drivers side
Loc- 2(+) twisted together ...2(-) twisted together...tapped into rear sub wires..RCA connected to amp
Amp comes on but no sound to speakers
Day2
Old Aug 20, 2010 | 02:29 PM
silly, but are the subs connected to the amp?
and inside the box are they wired up correctly?
do you have them crossed? meaning negative to positive and vice versa?
Old Aug 20, 2010 | 04:03 PM
1islandparadise's Avatar
Since you have a Type-S make sure you disconnect your rear mic because I blew my subs not doing this. ---> https://acurazine.com/forums/showthread.php?t=609759
Since the amp turns on then the wiring on it should be good (pwr wire, ground, remote wire, fuse installed on pwr wire and mini fuse). Make sure you have the RCA's are in the input of the amp. Some amps have multiple RCA's to add on additional amps.
Also if you have a ground cable on the LOC, make sure it has a good ground. If this doesn't work, pm me again....
Old Aug 21, 2010 | 06:33 PM
Mr3lite's Avatar
so i blew the amp.. idk... just order another alpine 1000.... will let you guys know the outcome....
will i need to buy a new amp kit or loc?
Old Aug 22, 2010 | 12:42 PM
Did you blow the amp or the fuse in the amp? Most amps have fuses, see if yours are blown before going out to buy another amp. The LOC and your AMP kit should be good. Double check your inline fuse on your power wire to see if that fuse has popped also. Also if you are using fuse #32 for accs power, check the fuse there also.
Charles Bennett
Jan 28, 2018 08:53 PM
Jul 16, 2017 07:33 AM
mvidal6
ILX
Nov 14, 2015 07:43 AM
justin.w13.walker
Sep 22, 2015 02:21 PM
