07 TL-S sub/amp install Q - ANC
2012 SH-AWD / Advanced
I've read a few posts on here about installing an aftermarket amp and sub in the '07 TL Type S. It appears that in order to do this, you must disconnect the automatic noise cancellation system. I just want to verify this.
If this is the case, which is the best (easiest?) method of disconnecting this...disconnect each of the mic's, disconnect at a "main anc terminal", fuse box, etc.?
Thanks in advance.
Thanks in advance.
THE PLANE TAKES OFF!!!!!
I did this... and disconnected the microphones.
It's VERY easy to snap the covers off, takes about 15 seconds each. Simply unplugs, completely reversible.
Hope that helps.
Hope that helps.
Originally Posted by TSC17
Somebody else can correct me if I'm wrong, but I believe the mics are different for ANC and voice commands/bluetooth.
The sounds cancellation mics are the SMALL holes in the front, and the only set in the rear
mrkingstonvi
02-22-2016 01:53 PM
