'04 TL Acura TL Non Navi To '08 Navi Conversion
#121
I need help building the harness. Please help
I’m trying to do this conversion but I’m having trouble figuring out how to properly build the harness
It took me about 9 months to complete the conversion due to troubleshooting.
Okay, long story short;
My ride is an 04.. the screen, navi, sub display, radio and DVD is an 08..
$380 CDN including the navigation unit, display, sub display, Radio and DVD/4.62
$65 for the 05/HFL unit
$65 for the 05 XM Receiver
$135 for the steering wheel switch, cover, bolts, washer, bulb ect…
$125 for the navi trunk cover
$200 for the wiring harness(DIY)
$300 for 04/08 Service and ETM
$75 for 2, 4, 5 conductors w/ ground wire insulated wire
Sorry, I didn’t taken much pictures during the conversion....because most guys already know the step by step for removed the trunk, center compartment and front rear seat.
Here is the connector I use to build the harness and soldering with heat shrinking...
For Navigation
http://i295.photobucket.com/albums/m...2/DSC01538.jpg
For Display (I forget taken a picture for the blue harness)
http://i295.photobucket.com/albums/m...layandhvac.jpg
For FCAN HIGH/LOW, VSS
http://i295.photobucket.com/albums/m...2/DSC01543.jpg
After these harness completely build and installed
Here’s the startup screen (took a lot of picture for this section, because my car is 04. Just make sure!)
http://i295.photobucket.com/albums/m...142/Starup.jpg
Home Map
http://i295.photobucket.com/albums/m...42/HomeMap.jpg
Navi Diagnosis
http://i295.photobucket.com/albums/m...2/DSC01605.jpg
Display Check
http://i295.photobucket.com/albums/m...42/Display.jpg
Color Pattern Check
http://i295.photobucket.com/albums/m...olorPatern.jpg
http://i295.photobucket.com/albums/m...2/DSC01638.jpg
http://i295.photobucket.com/albums/m...2/DSC01644.jpg
Navi ECU check
http://i295.photobucket.com/albums/mm142/TL142/ECU.jpg
FCAN Check
http://i295.photobucket.com/albums/m...L142/F-CAN.jpg
GPS INFOR
http://i295.photobucket.com/albums/mm142/TL142/GPS.jpg
Hard Key Check
http://i295.photobucket.com/albums/m...42/HardKey.jpg
Radio Check
http://i295.photobucket.com/albums/m...L142/Radio.jpg
XM check
http://i295.photobucket.com/albums/mm142/TL142/XM.jpg
YAW RATE Check
http://i295.photobucket.com/albums/mm142/TL142/Yaw.jpg
DVD Version
http://i295.photobucket.com/albums/m...DVDVersion.jpg
Night Mode
http://i295.photobucket.com/albums/m...2/DSC01603.jpg
Here’s the mirror issues were found as follows;
# 1 – Microphone/the part is on the way. (after I remove the interior light and found nothing inside, that’s why need to be order)
# 2 – XM Antenna/still thinking how to install this, need to drill hole…(I have the original cable and the antenna)
I still have to finish the mic sometime next week..... the part on the way. For the XM antenna, I still figure it out where I suppose to place.
If anyone want to know the troubleshooting, please feel free to ask and pm me…Because the 08 EMT is wrong!
For Navigation
Home Map
Navi Diagnosis
Display Check
Color Pattern Check
Navi ECU check
FCAN Check
GPS INFOR
Hard Key Check
Radio Check
XM check
YAW RATE Check
DVD Version
Night Mode
#123
#124
#125
You got any response on building the harness? I'm working on it as well and not sure where the F CAN Lo and F CAN Hi from the XM harness goes to? Anyone knows? I got the EMT but tracing the wire it just says it goes to the COMPUTER DATA LINES SYSTEM. Not sure where that is. Some help?
HondoGermany
23
01-08-2016 03:01 PM
handsom-hustla
11-13-2015 05:04 PM
Gianni Formica
09-07-2015 08:28 PM
asahrts
09-04-2015 05:55 PM
