'04 TL Acura TL Non Navi To '08 Navi Conversion
Old 12-28-2017, 03:28 PM
  #121
Yung King YK's Avatar
I need help building the harness. Please help
I’m trying to do this conversion but I’m having trouble figuring out how to properly build the harness
Originally Posted by kenny416
It took me about 9 months to complete the conversion due to troubleshooting.
Okay, long story short;
My ride is an 04.. the screen, navi, sub display, radio and DVD is an 08..
$380 CDN including the navigation unit, display, sub display, Radio and DVD/4.62
$65 for the 05/HFL unit
$65 for the 05 XM Receiver
$135 for the steering wheel switch, cover, bolts, washer, bulb ect…
$125 for the navi trunk cover
$200 for the wiring harness(DIY)
$300 for 04/08 Service and ETM
$75 for 2, 4, 5 conductors w/ ground wire insulated wire
Sorry, I didn’t taken much pictures during the conversion....because most guys already know the step by step for removed the trunk, center compartment and front rear seat.
Here is the connector I use to build the harness and soldering with heat shrinking...
For Navigation
http://i295.photobucket.com/albums/m...2/DSC01538.jpg
For Display (I forget taken a picture for the blue harness)
http://i295.photobucket.com/albums/m...layandhvac.jpg
For FCAN HIGH/LOW, VSS
http://i295.photobucket.com/albums/m...2/DSC01543.jpg
After these harness completely build and installed
Here’s the startup screen (took a lot of picture for this section, because my car is 04. Just make sure!)
http://i295.photobucket.com/albums/m...142/Starup.jpg
Home Map
http://i295.photobucket.com/albums/m...42/HomeMap.jpg
Navi Diagnosis
http://i295.photobucket.com/albums/m...2/DSC01605.jpg
Display Check
http://i295.photobucket.com/albums/m...42/Display.jpg
Color Pattern Check
http://i295.photobucket.com/albums/m...olorPatern.jpg
http://i295.photobucket.com/albums/m...2/DSC01638.jpg
http://i295.photobucket.com/albums/m...2/DSC01644.jpg
Navi ECU check
http://i295.photobucket.com/albums/mm142/TL142/ECU.jpg
FCAN Check
http://i295.photobucket.com/albums/m...L142/F-CAN.jpg
GPS INFOR
http://i295.photobucket.com/albums/mm142/TL142/GPS.jpg
Hard Key Check
http://i295.photobucket.com/albums/m...42/HardKey.jpg
Radio Check
http://i295.photobucket.com/albums/m...L142/Radio.jpg
XM check
http://i295.photobucket.com/albums/mm142/TL142/XM.jpg
YAW RATE Check
http://i295.photobucket.com/albums/mm142/TL142/Yaw.jpg
DVD Version
http://i295.photobucket.com/albums/m...DVDVersion.jpg
Night Mode
http://i295.photobucket.com/albums/m...2/DSC01603.jpg
Here’s the mirror issues were found as follows;
# 1 – Microphone/the part is on the way. (after I remove the interior light and found nothing inside, that’s why need to be order)
# 2 – XM Antenna/still thinking how to install this, need to drill hole…(I have the original cable and the antenna)
I still have to finish the mic sometime next week..... the part on the way. For the XM antenna, I still figure it out where I suppose to place.
If anyone want to know the troubleshooting, please feel free to ask and pm me…Because the 08 EMT is wrong!
Old 12-29-2017, 09:15 AM
  #122
kenny416's Avatar
hey I need some pix to show what kind of troubleshooting you have. plz
Old 12-29-2017, 09:34 AM
  #123
I don’t know how to build the harness
I need help I don’t know how to build the harness or what connectors I need to put the 08 nav in a 06
Old 12-29-2017, 10:39 AM
  #124
I didn’t get your pm
They didn’t send it through
Old 03-30-2020, 06:23 PM
  #125
Lee Thao's Avatar
You got any response on building the harness? I'm working on it as well and not sure where the F CAN Lo and F CAN Hi from the XM harness goes to? Anyone knows? I got the EMT but tracing the wire it just says it goes to the COMPUTER DATA LINES SYSTEM. Not sure where that is. Some help?
HondoGermany
23
01-08-2016 03:01 PM
handsom-hustla
11-13-2015 05:04 PM
iesu3423
09-29-2015 08:04 AM
Gianni Formica
09-07-2015 08:28 PM
asahrts
09-04-2015 05:55 PM
Quick Reply: '04 TL Acura TL Non Navi To '08 Navi Conversion
