Wrap Vinyl
Yes like everyone said don't cheap out on the product. Go with Oracle or 3m. I've worked with both and prefer Oracle. Biggest thing when wrapping your car is cleaning every part of your car especially cracks with isopropyl until their is no more dirt to ensure the vinyl sticks so that the vinyl doesn't peel off. You also wanna set aside 20 hours aside to wrap the entire car. Get a friend to give you a hand and it will be much easier doing the big pieces.
Thank you guys for your advice! I am only going to wrap my grille, but I was curious if it was worth the 150$ I got quoted from a 3M certified place. Or is it easy enough to do myself and save the money...?
I've had my front grill wrapped twice now.
The first time around I did it myself and it took like 2+ hours just to do the center bar. It was very frustrating and hard to contour it perfectly. You have to hold the grill in place while at the same time use both hands to pull, stretch and wrap the vinyl around the center grill. You have to have a blowdryer to heat up the vinyl so it gets very soft and easy to work with.
I had a nightmare and ended up kind of messing up and had a big air bubble but just left it anyways. It lasted for almost 2 years than one day I drove it through a car wash (never again) and the high pressure water ripped the vinyl because of the air bubble.
Second time around I sent it to AckTL05 so he could vinyl it for me and even he had a hard time. It came out a lot better than what I did the first time around but it's still no where near perfect. I just accepted it, no complaints here.
You might have better luck doing it yourself than I did.
Thank you all for the info and advice, If I peel the vinyl back up after stretching it to fit, does it leave any residue behind on the grille? also does I need the 3M primer and sealant?
used 3M Scotchprint 1080 in matte black. Did not need primer since it is non-porous. Hit it with 800 grit sandpaper just to take off the road wear and give the adhesive something to stick on. Used a heat gun, razor blade and it was a total pain in the ass. The radii are REALLY tight in some spots. Eventually it peeled up in the corners. Pulled it, re-sanded, and plasti-dipped it. It has held up for 2 yrs that way.
Wrapping the top hood trim and lower "V" shaped trim is very simple and easy.
The center bar with the "A" emblem on it is the most difficult. I wouldn't be surprised if he got the C-Mod grill because he couldn't wrap his center bar perfectly in carbon fiber lol
That's a aftermarket grill. I believe it's called a "C-Mod Grill".
CL-S progression 01
Jan 26, 2016 04:15 PM
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
oyayjoe
Sep 12, 2015 04:40 PM
