Windows control unit bad?
Old Jan 25, 2020 | 11:40 AM
JDiddyC's Avatar
I have a 2008 TL Type S and...
I replaced a passenger window motor and regulator after having weird issues with the window stopping and seemingly slow. I had already tried resetting the head unit for auto up/down. However now I can't get the thing reset and trying the manual method with key on and off holding buttons... It will sometimes stay up unless I hold down and just no auto up/down. Everything for the driver side works. I've not reset that side in fear of making it not work.
Is there any good way to test or check the expensive window control/ head unit on the driver door? Is it possible it's bad or I got the wrong door motor and regulator?
Dorman 751-047 Front Passenger Side Power Window Regulator and Motor Assembly for Select Acura Models https://www.amazon.com/dp/B00IWRDKKU/ref=cm_sw_r_cp_apa_i_QKhlEbAQ4ZS90
Please help.
Old Jan 25, 2020 | 01:14 PM
GhostTL09's Avatar
sounds like you need new regulators
Old Jan 25, 2020 | 05:14 PM
csmeance's Avatar
did you clean the glass channels? If it needs lubrication the motor could be kicking it back for the anti-pinch feature so you don't cut off fingers.
boostd92
Mar 19, 2018 09:29 PM
Sterling
May 26, 2016 05:27 PM
Paladuck
1G TSX Problems & Fixes
Feb 4, 2011 10:15 PM
billlikessuger
14
Dec 28, 2006 08:51 AM
