window regulators/leather?
Old Oct 1, 2004 | 11:03 AM
dv8ing's Avatar
someone elses Avatar?????
Question to all you '04 TL owners,
have you guys had any of your window regulators changed or fixed *under warranty*?.
I have had two and going on three replaced.
Here is how it happens, a couple of times I noticed the windows in the front making a slight grinding noise or jsut awkward noise that I thought should not be there. Took it in to the dealer for oil change and casually brought it up and they said they would take a look. well this happened on my left rear window also, and dealer said the same thing "we will take a look" anyway each time it resulted in my making an appointment to get the window regulator changed. Anyone else experience this with their windows? And what the hell is a window regulator, i always forget to ask them since they are swapping it out for free.
and on the same token has anyone else had their leather replaced due to cracking/wrinkling? I did!!!
T.I.A.
dv8ing
Old Oct 1, 2004 | 11:06 AM
Ron A's Avatar
Administrator
The window regulator is the thing with gears and arms that connects the window to the motor that opens and closes the window.
I have not noticed any problems in the past reported in this forum, as far as I can remember.
Old Oct 1, 2004 | 11:11 AM
mikedjpn's Avatar
I have heard the same noise before from both front windows. It hasn't done it for a while, so I kinda forgot about it. Thanks for the reminder though. I will have them look at it the next time I have the oil changed.
Old Oct 1, 2004 | 11:16 AM
grktl's Avatar
I have this happen a few times a month. When i take it in, then can never get it to happen.
Old Oct 1, 2004 | 11:26 AM
dv8ing's Avatar
same with me but when they take apart and start looking into it they say need to replace.
they did try to fix my front pass. window but that did not help so it was replaced as well. next one is my right rear going in next week. also complained about the moon roof making a weird nose as well not sure what the outcome of that one will be.....
Old Oct 1, 2004 | 11:52 AM
J2004TL's Avatar
my car is going on 2nd time for the the same problem.
i noticed it when i had my window about 4-6 inches down then shut the door and it sound like a bang against the glass and you can see it move too. but when i took it the first time to get fix b-cuz they say its the regulators it still happened now they say there going to order new regulators. i dont know whats going on yet.
Old Oct 1, 2004 | 12:34 PM
dv8ing's Avatar
I'm sure they will get it right one of these times
Old Oct 1, 2004 | 01:51 PM
i've had the same problem....my passenger side window's regulator/sensor was messed up....the window would go up an inch and then automatically come back down...i complained to the manager at the dealership and they fixed it...at the same time, they replaced the driver side motor/regulator/sensor because i thought that the window was going up slower than it normally did...but no leather cracking problems as of now...
- J
Old Oct 1, 2004 | 02:17 PM
need4spd's Avatar
an Acura has-been
They replaced my rear pass window regulator, and drivers leather.
Old Oct 1, 2004 | 02:50 PM
Lore's Avatar
CEO, Team Anthracite
My windows make that grinding noise too when the car's been parked in hot weather. Otherwise it still works okay.
Old Oct 1, 2004 | 03:54 PM
dv8ing's Avatar
yeah that is when i would notice the grinding noise too, that is why i had taken it in and that is what they did (replaced the regulators)
yeah i had my driver seat and that rear seats replaced, they were really bad. And now i think it is going in for the front passenger as it to is starting to look bad.
Old Oct 1, 2004 | 04:03 PM
yzfrebel's Avatar
My front pass window is currently making a grinding noise also. The dealer has the part on order. Maybe I should have them check the rest of them when I take it back in if people or having the same problem on multiple windows.
Old Oct 1, 2004 | 05:10 PM
nick04tl's Avatar
T.I.A.
dv8ing
i think we have had 2 or 3 of them replaced at my dealer for a grinding noise.
Old Jan 4, 2005 | 12:19 PM
palmultiacura's Avatar
Window Regulators - Going in 6th time
I have never posted...but am a big fan of the site (both before and after buying my TL).
I first noticed the problems with the windows at about 10k miles. Noise got worse and worse and finally I brought it in (1st visit). They greased the regulators made it better for a day or two. Went in again (2nd visit) and had them "adjust" them again. They greased the crap out of the regulators (and windows) Had to go back and have them use a razor blade to clean them (3rd visit). Still squeeked, went in again (4th visit) and I demanded they replace the regulators, which they did (visit #5). After another 10k miles I noticed a little squeaking....went away. Was out with a client today, rolled down the windows and BAM full blown grinding and squeeking. I was actually embarrased of the car. I have noticed that with other cards after a car wash if you roll the windows down they smear the water on the windows...not with this one. I don't think the rubber seal works to prevent water/dirt from entering inside of windows.
I don't mind the leather problems, but the damn windows, don't know what to do. Gotta run and call the dealer. I will let you know how Acura resolves the problem.
I have faith in the dealer and the company.
Sorry for the long post, just had to let it out!
Thanks for all the great posts!
PalMulti
Old Jan 4, 2005 | 07:12 PM
antho2006's Avatar
wow, sounds like a BMW e46 forum....
Old Jan 5, 2005 | 04:17 AM
JetJock's Avatar
I've had window regulator problems with my '94 Honda DelSol, but none with any Acura I've ever owned...I'm on my 4th now with no problems.
Old Jan 5, 2005 | 02:42 PM
PoochaKannInc's Avatar
Shift_faster
I've had my front passenger window regulator replaced at around 9K miles. No problems since (I'm at 13.5K right now).
Old Jan 6, 2005 | 11:30 AM
dv8ing's Avatar
PalMulti
dude that suck you had to go 5 times already!
I had them replaced the first time I noticed it and it wasn't even as bad as yours sounds.
le^2
Mar 17, 2026 05:06 AM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
AcuraKidd
Sep 25, 2015 11:18 PM
