wimpy trunk light
wimpy trunk light
Has anyone successfully upgraded the light in the trunk? I'd like to install a brighter light, but I'm not sure of what the OEM system can handle. I don't want to melt the light cover either.
Any advice is greatly appreciated.
Originally Posted by TLGator
Congratulations on finding something new to complain about on the TL!
Winpy Trunk Light Fix
QUOTE=TLspeed]Has anyone successfully upgraded the light in the trunk? I'd like to install a brighter light, but I'm not sure of what the OEM system can handle. I don't want to melt the light cover either.
Any advice is greatly appreciated.[/QUOTE]
I replaced the 5 watt trunk lamp bulb with an 11 watt Malibu yard light bulb from Home Depot - outdoor lighting section. No problems with the higher wattage. You could bump it up from 5 to 7 watts if you don't want to go that high with the 11 watts. Could even change out the overhead interior (front & rear) as well as the door lamps too.
I thought so too--ended up picking up 2 door lights from a Acura Legend with charcoal interior and installed them into the sides of the trunk. (Had to cut into the trunk lining though for a flush fit)
I wish there were an easy way to turn off the trunk light, like when you are at a tailgate. In my old 1986 Legend I used to pull the fuse for that light. Now I just close the trunk lid. This is hardly unique to the TL as my last Accord was the same.
mada51589
Jan 9, 2025 04:40 PM
handsom-hustla
Nov 13, 2015 05:04 PM
EE4Life
Sep 11, 2015 10:13 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
