Not another A1 service thread.
Old Aug 19, 2004 | 06:40 PM
6mtV6's Avatar
I6
Has anyone that had the A1 service show up on the MID only do the oil change and not the tire rotation part?
A1 is oil change and tire rotation right?
Old Aug 19, 2004 | 06:44 PM
svtmike's Avatar
I did only the oil change. I get free tire rotations from Discount Tire for the life of my Michelin tires.
Mike
Old Aug 19, 2004 | 06:49 PM
GunnmeTaLCURA04's Avatar
GÜNnµ ¡Ï
yeah i just did my oil change. The acura dealer here in Esserman, told me that it wasnt really needed. To do it in my B1 service. But i think i might have another A1 before a B comes around. And hey quick question.. I am gettin more milage this time. i did my first A1 with 4200 miles now i am at close to 9000 and i am still at 40%. does this keep on getting better. Or never mind all of you are going to say. Depends on how you drive. haah
Old Aug 19, 2004 | 06:55 PM
6mtV6's Avatar
I6
Depends on how you drive. LOL
Does the dealer tell you that you only need the oil change or you decided yourself? The full A1 service is like $119 and oil change is $29.99.
I have about 4700 miles now and oil life less than 5%. Should I get the full A1 or just the oil change?
Old Aug 19, 2004 | 07:16 PM
Ron A's Avatar
Administrator
A search on A1 (only one letter and one number, and close to each other on the keyboard) will give you more than enough info on your question.
Old Aug 19, 2004 | 08:56 PM
ali_enterprises's Avatar
Semper Fi
Old Aug 19, 2004 | 10:09 PM
6mtV6's Avatar
I6
I did search prior. It didn't really cover if people only got the oil change and not the tire rotation or got both.
I just wanted to know how many people actually just got oil change.
My dealer quoted me $29.99 for oil change and $119 for the whole A1 service. If A1 is just oil change and tire rotation than isn't it kind of expensive to pay $89 for tire rotation? Is that how much it costs at the dealer?
Old Aug 19, 2004 | 10:19 PM
bnandreu's Avatar
Team Anthracite Member
Just the oil change for me, $26.28 at the dealer.
Bought 100% Road Hazard Warranty for all four tires incl lifetime balance and rotation for $172 from Discount Tire. Anything happens to the tire and it can't be repaired I get a full replacement for free.
Yes, I did keep the reformulated EL42s because I don't get much flatspotting in the Texas heat.
Old Aug 19, 2004 | 10:52 PM
rets's Avatar
Moderator Alumnus
I'm sure this was covered before, but the precise answer may be submerged by mile high posts. U may have to check answers one by one sometimes after SEARCH.
A1 is supposed to have Oil Change plus Tire Rotation only, but dealers would throw in 03TL's 5k or 7.5k maintenance service package to you. That's why it costs $119 or whatever $$ is. This doesn't mean $89 = tires rotation. $89 includes the whole bunch of check-ups.
(Note: Some ppl do get free vouchers for oil change/oil filter. )
I suggest you could get Oil Change from your Acura dealer, then find a reputable tires shop for rotation.
Or DIY.
Old Aug 20, 2004 | 01:37 AM
6mtV6's Avatar
I6
I got free vouchers for oil change/oil filter which includes lubrication of key chasis and 19 point inspection like replenishing fluids.
What other check-ups could they do when rotating tires? Just wondering.
The dealers should be better informed on the different services for the 04 TL.
Old Aug 20, 2004 | 02:03 AM
rets's Avatar
Moderator Alumnus
What I got for my A1 = 03TL's 7500 miles maintenance service...
change engine oil/filter,check/top all fluid oil levels, replace wiper refills, inspect fuel lines, inspect/adjust all drive belts, pressure test cooling system, check all cooling hoses & connections, inspect water pump for wear & leakage, inspect front & rear brakes, calipers for leaks & damage, master cylinder & brake hoses, ABS brake components, parking brake adjustment, test clutch & inspect hydraulic system, rotate tires & set pressures, CK alignment, lubricate locks & hinges, inspect underbody, exhaust system for leaks, tie-rod ends, steering, boots, all suspension components, dirve shaft boots, test alternator output & battery, all lights & controls, seat belt operation, check for out of alignment head lamps, test operation of air conditioning, operation & function of cruise control, road test & wash car.
I posted this on Jan. 04, 2004.
Old Aug 20, 2004 | 02:23 AM
Xpditor's Avatar
Brave New World
Originally Posted by rets
..... road test & wash car.
You let them wash your car??
XP
Old Aug 20, 2004 | 02:46 AM
rets's Avatar
Moderator Alumnus
XP
That's part of services in the list. You could say NO. Some dealers do use brush to rub your car. Pay attention to this service before you nod.
Old Aug 20, 2004 | 02:55 AM
6mtV6's Avatar
I6
Jan. 04, 2004 I wasn't even a member of this site. The 04 TL wasn't on my mind. LOL
Thanks for posting this info again.
Old Aug 20, 2004 | 07:04 AM
JetJock's Avatar
I wonder how much time they actually spend doing all these "inspections"....I'd bet money that it takes them less than 15 minutes beyond the oil change and tire rotation to "inspect" everything...what a ripoff!!
Old Sep 28, 2004 | 08:08 AM
ibeplato's Avatar
I'm at the dealer now for an A1 service. The service writer told me that the only service due is an oil change. A tire rotation would be due at 10k.
I've got 6,300 on the car, this is the first service.
Old Sep 28, 2004 | 09:04 AM
narnia's Avatar
Team SSM Queen
When I had my Hondas, my service dept. always had sheets available listing all the service costs, when service is due, and a detailed list of what's done to your car. Acura service depts. have nothing like this for their customers?
Mike734
Dec 10, 2021 01:25 PM
08KBP_VA
Oct 22, 2019 01:55 PM
thegipper
Sep 28, 2015 01:01 PM
jmaxima03
Sep 27, 2015 10:22 AM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
