What's the mileage on your 3G? Still going strong?
Old 03-07-2014, 11:32 AM
  #721
tkeo's Avatar
2004, almost at 78k. Pretty good so far.
Old 03-09-2014, 09:00 AM
  #722
Due_Diligence's Avatar
2004, third owner, w/143k.
Doing the following maintenance to the car once it warms up
-oem front shocks
-oem front motor mount
-3rd and 4th gear pressure switches
-3x3 ATF
-oil change
The timing belt and water pump have already been done which I'm grateful for.
Then she'll be running like new again.
Old 03-09-2014, 07:31 PM
  #723
shirknasty21's Avatar
93k on my 08 TL. Strong running machine! love it!
Old 03-09-2014, 07:36 PM
  #724
under renovations....
CubanLynx84's Avatar
2008 with 65k on it. Got it in February 09 new
Old 03-10-2014, 09:44 AM
  #725
9th Gear
4thof5's Avatar
I have about 220k on a 05 5at. I bought it with 50k on it. Main issues with the car, side mirror motors, HFL (I have co-worker who went in with a seperate issue said his HFL was replaced due to a recall), navi went out. Otherwise care seems to be running great.
backthatACup (03-23-2014)
Old 03-10-2014, 07:40 PM
  #726
6th Gear
ThatOneBlueTL's Avatar
I have about 73k on my '07. Bought it with 36k so they rest are mine. Runs amazing still!
Old 03-10-2014, 08:14 PM
  #727
3gstealth's Avatar
06 5AT 64k
Purchased new on 8/30/06. Still like new in every way.
Old 03-10-2014, 08:55 PM
  #728
One on the right for me
subinf's Avatar
Almost at 224k. Not as many miles in Feb due to the car sitting in the shop for the better part of two weeks.
Old 03-11-2014, 05:00 AM
  #729
cantojai's Avatar
2004 TL 175,000.. No problems whatsoever..
Old 03-15-2014, 09:46 PM
  #730
Hoopcanada's Avatar
2004 AT
bought it two years ago with 157k km, now 190km, generally no problem
navi failed me, every now and then DRL light comes on after applying the handbrake, one O2 sensor failed, changed a battery(errrr it's freaking cold here in Canada), changed 3 out 6 spark plugs(after changing out the front 3 plugs and one from the back, I realized plugs were "new" and still good for another 3,4years)
did 3X3 one time 30k kmago, haven't replaced the pressure sensors yet.
I would rate 9/10 for TL's realiablity
Old 03-16-2014, 07:42 AM
  #731
6th Gear
Roger type s's Avatar
Just turned 90,000 running like a top!
Old 03-18-2014, 10:07 AM
  #732
"It's On and Poppin"
diaboliq1's Avatar
A 2004 TL with 158K and it almost runs like it did in 2004. I adjusted the valves and changed the spark plugs in August 2012 and that seemed to turn the clock back to 2004.
Old 03-20-2014, 07:46 PM
  #733
Nmm555's Avatar
106K on my 08 CBP!
Old 03-21-2014, 12:39 AM
  #734
XtraKrispy's Avatar
2006 6spd with @26k on it. Bought new in Oct 05.
Old 03-22-2014, 01:48 AM
  #735
6th Gear
markpreardon's Avatar
82,950 on my 2004 TL. BONUS: the last owner never drove it in the winter so my underbody is cleannnnnnn. I bought it in Connecticut but I'll be moving back to the Southern California Area before next winter so I should be able to keep this "no winter" streak alive.
Old 03-22-2014, 07:18 AM
  #736
quake97's Avatar
I'm at 92k on an 06 TL. Saving up for the 105k maintenance for next year.
Joe
Old 03-22-2014, 05:25 PM
  #737
subinf's Avatar
Pushed past 224k a few days ago. Not doing as much driving this year so far.
Old 03-22-2014, 06:05 PM
  #738
07TLGUY's Avatar
07 with 72k...
Old 03-22-2014, 06:36 PM
  #739
5th Gear
Redline459's Avatar
08 Type-s 22' k
Old 03-22-2014, 09:45 PM
  #740
TomandGrammy's Avatar
04 with 102k. Runnin like a boss!
Timing belt/water pump changed
Spark plugs switched
3x3 ATF Drained/Refill
Pressure switches changed
Old 03-22-2014, 09:58 PM
  #741
skora89's Avatar
Just got my 2008 CBP at 53k miles
Old 03-23-2014, 01:54 PM
  #742
6th Gear
kristina's Avatar
142k 05 vroom vroom
Old 03-24-2014, 08:01 AM
  #743
cruz3468's Avatar
47k 2007 tl type s
Old 03-24-2014, 08:21 PM
  #744
ct_ua6's Avatar
2005 MT got 93k on it still running like a champ
Old 03-24-2014, 08:47 PM
  #745
07_TL_S's Avatar
07-tls 90k runs greats
Old 03-24-2014, 11:36 PM
  #746
euhs21's Avatar
07 AT TL, second tranny, blew 4th gear in the original. Slight lifter tick, car has been beat on for 175k miles and still takes it like a champ. Regular ATF changes every 30k and oil every 5k.
Old 03-25-2014, 02:32 PM
  #747
08 MDX, 04 TL (sold)
jhumbo's Avatar
Interestingly enough, my HFL started flaking out at 37k and it was replaced under warranty. Had no issues for the remaining life of the car. (I sold the car 7 years later with 194k miles.)
https://acurazine.com/forums/3g-tl-2004-2008-93/my-100-000-mile-journey-maintenance-graphs-charts-803409/
Old 03-26-2014, 10:52 PM
  #748
2008 WDP Base TL
kev08wdp's Avatar
Adopted my base WDP 6 year old 2 weeks ago at 126k and the only thing wrong with the drive is the atf should be changed. I need a little help and some reassurance about getting Redline and which one to get
Old 03-29-2014, 09:12 PM
  #749
Boogsephine's Avatar
Just hit 80k in my '08 TLS 6 speed. No problems at all minus the cruise control not working. The car has been sitting for the past 9 days and won't be driven again until a week from Thursday. I've been driving the Honda Pilot around since I've been doing a lot of highway miles. Kind of nice to have an automatic to fall back on when traveling.
Old 03-29-2014, 09:54 PM
  #750
desibaba's Avatar
I have a 05 with nav with 104k. Just did the timing belt, water pump and spark plugs. Lately the ride seems a little "Bumpy" so I wonder if I need springs or shocks?
Old 03-30-2014, 04:27 PM
  #751
pirate0188's Avatar
My 05 TL 6M has 197K. No issues.
Old 03-30-2014, 05:30 PM
  #752
masterelvis01's Avatar
2006 base model, 136xxx no problems whatsoever
Old 03-30-2014, 08:04 PM
  #753
3rd Gear
StrongestOfChins's Avatar
04 TL with the 6-spd and Navi. 170k on the clock right now, bought it a year and half ago with about 140k on it for 7-grand. I've had to replace a few things though. Starter, motor mounts, master cylinder, slave cylinder, and the clutch. Even with these repairs, I don't regret buying it, and plan on keeping it till about 200k.
Old 03-31-2014, 12:41 PM
  #754
Q('.')=O
imj0257's Avatar
About to hit 130k.
Other than the clearcoat peeling off 3 of the wheels, the badly cracked dash, the right seat warmer light not working, the broken cup holder sliding cover, the really oxidized left headlight, the big scuff on the bottom of my front lip, the scratch on the rear bumper, and the a/c not blowing as cold as it used to, it is still going strong!
Old 03-31-2014, 08:55 PM
  #755
Earlrabbit's Avatar
Just turned over 17K on my 2007 TL type S. Barely broken in.
Old 04-10-2014, 10:37 PM
  #756
Registered Big Dog
BC2G's Avatar
04 tl 5at just hit 100k --She is strong and runs great; like the day she drove off the lot...
-oil jet installed on tranny under TSB
-Side motor mount broke (so i replaced them all about a week ago)
-about to do the 105k service (including thermostat and water-pump)
-About to change the tranny fluid w/ Redline racing (this will be the 2nd fluid change in the tranny as the first was done around 60k when the oil jet was installed)
-About to install Raxles to hopefully stop the low rpm shutter that happens around 1800-2000 rpm around 30 mph...
Couple things:
-clear coat may be bubbling (i dont think the paint quality is the best and i wash with professional supplies that never touch the ground and high grade car shampoo).
-She has been a road warrior and been on road trips thru mountain roads so the paint on the front is good and nic'd up from the rocks...)
Old 04-11-2014, 12:13 AM
  #757
subinf's Avatar
226k now.
Driver side headlight went out the other week. 10 years isn't bad. Just replaced both on Tuesday.
Old 04-11-2014, 12:56 AM
  #758
0utl's Avatar
04 6MT with 144k runs and drives smooth! Been hibernating since January while im attending school in Hawaii. I miss driving it!
Old 04-11-2014, 02:54 AM
  #759
TSX-S2000's Avatar
Getting close to 216K miles.
Old 04-12-2014, 03:20 PM
  #760
2FRESHTL's Avatar
2008 tls 30 k
Quick Reply: What's the mileage on your 3G? Still going strong?
