What for a Transmission oil?
I read the new transmission oil is the ATF DW 1 in Germany we use ATF Z1!
What is better DW 1 or Z1?
BANNED
redline.
Meacura86 (04-12-2013)
Received 3,824 Likes
OP, read this...
https://acurazine.com/forums/3g-tl-2004-2008-93/optimal-percentage-racing-atf-834299/
In short, you'll want to use a combination of Redline D4 and Redline Type-F fluid. (1 quart D4 and 2 quarts of the Type-F).
it very complecated the one people say this the other say that
I have to look if it exists in Germany!
The Transmission of honda should be very sensitive to oil
Meacura86 (04-14-2013)
I use DW1. 151k miles on my original tranny (2005). Regular fluid changes as well as changing the 3/4 transmission switches.
My first ricer
How about some pics of your car? Where did you get it imported from? I thought they were only available in the US/Canada/China.
TLicious Type S
Wow, it's so interesting how many different opinions there are on this. I'll add mine to the list--my theory (hope) is that the Honda engineers would know best what kind of fluid works with their transmission design. Honda has a serious vested interest in the reliability and long life of their vehicles, and design their fluid specifically for their transmissions.
I use the newer Honda DW1 (that replaced Z1).
I use DW1, too.
DW-1 every 10k miles after the 3x3, Z1 had been discontinue.
Meacura86 (04-16-2013)
DW-1 and a bit of type F
![](http://i1284.photobucket.com/albums/a568/LegitUA6/F20277FC-7CBB-46E0-B8F7-0EAB3E803DA1-13534-0000073D1A96D1BA_zps9a8106d7.jpg)
![](http://i1284.photobucket.com/albums/a568/LegitUA6/3AA144D9-2E5F-45C9-94EC-EE599E9328AB-11560-00000657DA67FD27_zpsa001b5f6.jpg)
Here's what Ive been running. I've used this since Z1 has been discontinued. My transmission is original, no pressure switches, no repairs.
Everyone might have their preference but this has worked great for me!
Do you use sportshift often?
I'll be there soon, I'm at about 285k now!
I rarely ever use sport shift, IMO it's not very responsive.
And engine are 3.2 V6 this is a good motor no Turbo and high capacity and adequate performance! By Engine is it small performance and high capacity lives forever! So it can be a very long time
I'm always amazed at these threads. That eneos is a DexIII fluid. Use a Dex III fluid of your choice and it will last much longer than on the factory fluid. Redline D4 is DexIII. Pressure switches should be changed every 3 years for maximum life. A car with nearly 300k miles has seen mostly freeway use. When the car is cruising down the freeway it's not shifting so no wear is occurring to the clutches. If the clutches aren't used they can't wear out. It's great that its gone that many miles but it needs to be put in perspective.
TLicious Type S
Can you please expand on the use of Dexron III? I want to use what is best for the long life of my transmission. Can you explain exactly why this is better than Honda's DW1? Are there any tests comparing the two? What brand or blend of Dexron III do you think is the best for the TL transmission?
Thanks bro, I'm a new TL owner and am learning here, and am trying to separate speculation (which is what I'm doing when I choose DW1 simply because it's an OEM Honda product), from fact. Thanks as always for sharing you experience!
IBankMouse
06-13-2020 12:53 PM
SidhuSaaB
05-30-2020 12:40 AM
joflewbyu2
10-08-2015 11:16 AM
STL TL-S
09-23-2015 08:52 PM
