weight sensor coverd Under waranty ?
Hi, My Steler Told me that my passenger side Weight sensor needs to be replaced and it would coast me 810.xx $ should that be coverd Under waranty cose my car has Just 94000 Km on it. Any help plz
http://www.acuraoemparts.com/delray/...All&vinsrch=no " 81167-SEP-A12" and " 81168-SEP-A12 "
The DVD-A Script Guy
I doubt they are covered.
One sensor ? Both?
Even if both they are just under $400 at full list (which the dealer probably charges) Is it really 4+ hours to put them in? Looks pretty straight forward from the diagram. If you DIY it you could end up out $300 and still have a problem. Any other dealers you can get another opinion from ?
One sensor ? Both?
well this is what the stealer quoted me 240 x 2 for the sensor + 2.5 Hr = 237.38 = 717.38+tax i'm just planing to leave it like that or i might just return the car. what should i do ?
I got the Tl w/navi for 17900 $ + tax 94000 Km Automatic switch selector has to be replaced 450 $ + tax + something is wrong with the radio it woudnt load any disk
Can I ask you why this sensors went bad? Are they even tried to calibrate those sensors? Its hard to believe it just went bad. There are weight sensors, opds and module involved. Which one is bad? or all of them? I would tried airbag specialist for this w/ cheaper price or your insurance should cover if you have mechanical premium/
![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
here is the copy of the inspection they have done. Just one more thing do they have to check if teh cd player is working or not in the inspection or not and dont have have to check all the sensor too, because i have to replace the Automatic switch selector.
http://img185.imageshack.us/img185/2780/picture080.jpg
http://img185.imageshack.us/img185/6941/picture081.jpg
http://img14.imageshack.us/img14/7432/picture082v.jpg
Seems to need a lot of repairs at 94000KM, 58000 miles.
2 Weight sensors
Top motor mount
Front stabilizer bar links
Cracked wheel
Rear sway bar bushings
Was this car just purchased, and were the lights on at that time?
Did you run a Car Fax on the car, if it's even applicable in Canada?
Was this a CPO car that you just purchased?
Seems odd that both are on, as occasionally a module, sensor, or wiring could go bad in one system, but both?
Sure airbags are in the car?
2 Weight sensors
Top motor mount
Cracked wheel
2 Weight sensors
Top motor mount
Cracked wheel
2 Weight sensors
Top motor mount
Cracked wheel
well Front stabilizer bar links has been replaced for free by dealer
Cracked wheel Got a new one for free
Rear sway bar bushings also got it replaced for free
Axel was rebuild
now i have to fix is that top engine mount , Automatic switch selector , Cd player and those two sensors dealer is willing to give me 400 $ refound should i take it or return the car.
Axel was rebuild
Axel was rebuild
i am assuming you just bought this car? if so, how come dealer won't fix this for free? But if you buy for a long time , how can you return it?
If I buy this car recently and have this much problems i would return it because dealership did not inspect this car. Anyways, i dont know when this car purchased.
