Vtec
Old Nov 16, 2006 | 01:17 PM
Tone-NBP's Avatar
Vtec
Just curious, what happens if you never take your car above VTEC?
Old Nov 16, 2006 | 01:32 PM
rbf351's Avatar
Registered User
nothing at all
Old Nov 16, 2006 | 01:34 PM
simonsez's Avatar
A-SPEC
Your car would be still a "virgin"
Old Nov 16, 2006 | 01:35 PM
simonsez's Avatar
A-SPEC
but i gotta tell you...
vtec is fun...
Legend2TL's Avatar
AZ Community Team
Good question, I've wondered that also.
I sorta wonder or concern that the Vtec intake valve that only partially opens gets more accumulation of unburned fuel on it compared to the normally opening intake valve (the non-VTEC intake valve). Wheither or not this happens I don not know. The amount of air that moves pass that valve is much less, but the air flow is of high velocity so maybe that helps keep the fuel deposits low. For this reason I try to always take the engine to redline once it fully warms up whenever I drive but I really don't know if that makes any difference.
Old Nov 16, 2006 | 01:44 PM
Tone-NBP's Avatar
I remember when i had my GSR a friend told me to VTEC it once and a while because its good for the engine and i'm like uh ok..I didn't bothered to ask for his explanation. So now i'm a little curious.
Old Nov 16, 2006 | 01:51 PM
XS2K's Avatar
If I should VTEC more than once a day, will I go blind like my mother told me ?
Old Nov 16, 2006 | 02:08 PM
your_mom's Avatar
04 NBP 6MT
A posse of angry Honda engineers will come to your crib and beat you down for not taking advantage of their advanced technology they spent the best years of their lives developing.
I take mine above VTEC at least once a week. I try for every day, but with gas prices the way they are and the TL drinking premium... I figure it's good for the mechanical stuff that makes VTEC happen to be used and get some oil in it.
Old Nov 16, 2006 | 02:18 PM
rbf351's Avatar
Registered User
it doesn't affect a single thing. all it does is saves you gas
Old Nov 16, 2006 | 02:21 PM
Legend2TL's Avatar
AZ Community Team
In general for a gasoline or diesel internal combustion engine, it's good practice (and also fun) to run them up in revs and load occasionally to help burn off deposits on valves, piston crowns, and cylinder heads since the combustion chamber temps go up with higher revs and loads. So taking it up to redline in neutral is not the same as winding up WOT in the first 2-3 gears.
Hey it also may sound good enough for the police...
Old Nov 16, 2006 | 03:37 PM
JAB00's Avatar
Sorry to sound foolish but how does one take their car above VTEC? Is it considered redlining it?
Old Nov 16, 2006 | 03:49 PM
Final's Avatar
Opium den in
Hahahahah, enough said.
Old Nov 16, 2006 | 03:51 PM
sixsixfour's Avatar
i believe you just need to rev past 4700 and you've past it
IBankMouse
Jun 13, 2020 12:53 PM
Dunnik
Sep 15, 2015 11:52 PM
Tsov Tom
Sep 6, 2015 07:56 AM
Desert Ridge
Sep 5, 2015 09:47 AM
LAMike240
Sep 3, 2015 04:35 PM
