Vinyl Wrap on v-trim and grill????
Old 03-08-2011, 06:17 PM
Moding time
henrylo's Avatar
i been reading that what people should start doing to their vtrim and grill cause due to the paint chips and paint comming off.
Old 03-08-2011, 07:07 PM
guitarplayer16's Avatar
Received 2,316 Likes on 1,690 Posts
Yeah, Vinyl is great stuff!
Old 03-08-2011, 08:33 PM
'06 WDP TL 6MT
stvtec's Avatar
So, what are you asking? Yes you can use vinyl to wrap those parts. Personally I used Plasti-Dip and it has been holding up fine.
Old 03-08-2011, 08:47 PM
Moding time
henrylo's Avatar
whats that plasti-dip?
Old 03-08-2011, 08:50 PM
Chapter Leader (Houston)
TLDude876's Avatar
Received 1,085 Likes on 810 Posts
The most magical thing. Just spray it on and it sticks to the surface like rubber. If you dont like it just peel it off. I did my grille in vinyl and plastidip for the emblem.
Old 03-08-2011, 08:56 PM
ggesq's Avatar
Received 2,181 Likes on 1,210 Posts
http://lmgtfy.com/?q=what+is+plasti-dip%3F
Old 03-08-2011, 09:35 PM
Moding time
henrylo's Avatar
thankss,
how is the color match if i want to buy black for my nbp tl
well how was the color matched for you guys?
Old 03-09-2011, 02:51 AM
05 AM TL
kevinballer08's Avatar
It's a flat black. Find any black plastic you have looking around and that's how it looks like.
Won't match NBP exactly.
Old 03-09-2011, 07:50 AM
BANNED
SharksBreath's Avatar
Received 2,885 Likes on 1,784 Posts
good point...might as well get vinyl if you want it to match.
henrylo, the glossy black vinyl will match NBP almost perfectly. i got mine from http://www.stickercity.com
Old 03-09-2011, 10:36 AM
Forza Italia
FiBS-TLS's Avatar
Do you have a pic you can send me of your grill in vinyl/plastidip for emblem?
Old 03-09-2011, 01:36 PM
'06 WDP TL 6MT
stvtec's Avatar
I have pics in my album of my grill/bar painted with plasti-dip. The emblem is unpainted.
Old 03-10-2011, 11:23 AM
STeelTL's Avatar
i wrapped mines in the 3m carbon fiber dinoc vinyl...Looks great
Old 03-10-2011, 11:32 AM
rtibbitts07's Avatar
Did what I thought was a thorough paint job on my silver trim pieces about a month and a half ago, went through all the proper prep work, removed bumper, sanded the pieces to encourage the paint to stick, cleaned with rubbing alcohol, and painted about 5 coats of black paint that was meant for plastic followed by 3 layers of clear coat, with proper drying times between layers.
About a week after I did this, chips started to show up, and have only gotten worse. Nothing big, but still visible from 6 feet away. Plan on vinyl wrapping the grill in the next few weeks.
Old 03-10-2011, 01:26 PM
Moding time
henrylo's Avatar
is the cutting hard to do???
how long did it take you?
Old 03-10-2011, 01:41 PM
H.wood's Avatar
can the dip stuff be painted?
Old 03-10-2011, 01:51 PM
3G TL
ityper's Avatar
good question. i dont see why not?
Old 03-10-2011, 01:57 PM
H.wood's Avatar
lol, guess the only way to find out is to do it
Old 03-10-2011, 02:18 PM
MasterShake's Avatar
For those of you who vinyl wrapped the grill parts: does the vinyl stick to the little indentation on either side of the Acura logo?
I've heard that it can come out.
Old 03-10-2011, 02:41 PM
BANNED
^i did mine months ago and everything stuck just fine, and still is today. working with vinyl is pretty easy for the most part, getting around those challenging curves is the most frustrating. just make sure you heat the vinyl regularly so that it becomes pliable and will make the turns you want it to. use your fingers to press it into place when you get it where you want it. if it doesn't lay down properly, heat it up and pull it off and try again.
i took apart the entire grill and wrapped each piece individually, then reinstalled them. this ensures that every piece is safe from peeling off bc all the pieces are protected/overlapped by one another when reinstalled. just take your time with it.
Old 03-10-2011, 06:48 PM
STeelTL's Avatar
i did the middle bar and i didnt like it since it started peeling up....I also didn't spray it with adhesive primer either....the rest of the grill was fine...its just complex curves you have to worry about...i did the hood trim and v trim around the bumper...Left the middle piece stock
Acura604
2G RDX Photograph Gallery
27
10-08-2020 09:24 PM
iRaw
ILX Photograph Gallery
30
08-05-2016 04:41 PM
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
rhdune16
09-28-2015 11:31 AM
scionxb3003
09-22-2015 05:28 PM
Quick Reply: Vinyl Wrap on v-trim and grill????
