Vanity Light
Vanity Light
Can anyone point me to a DIY for replacing the lights in the visor that illuminate above the little mirrors? I want to replace with LED as the stock illumination is a joke (plus my wife complained).
Looks like the cover may just pop out but what LED bulb should I get? Does the led just snap right in?
Full of water...
use a piece of tape..like the clear kind or something thinner. just wrap a piece around the bulb and leave enough to form a handle...then pull. not sure if this method is needed for this specific bulb but it is for some. its been a while since i changed mine. there are a few threads out there that show how to get to every light in the TL...maybe even in the garage.
The 3g garage is your friend. I found this thread there:
https://acurazine.com/forums/3g-tl-2004-2008-93/definitive-led-thread-all-youll-ever-need-know-about-leds-3g-garage-g-076-a-633045/
the lens is a bitch to remove. i used a flathead screwdriver and just pushed it in and wiggled it left and right. the 3G garage shows you how to do it, but it takes a bit more effort than it looked.
once you pry out the lens, the bulb is in the connector that is part of the lens housing, identical to the trunk light.
i suggest practicing removing the trunk light first. once you figure out how to remove that, you can apply it to removing the vanity light.
hope this helps
hope this helps
AZ Community Team
Received 7,770 Likes
Service Manual Scans for removal here (Also from the 3G Garage):
F-001: Headliner, vanity/antenna module/XM antenna replacement/front and rear map light/vanity light
https://acurazine.com/forums/showthread.php?t=180141
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/leds-installed-night-pics-635033/#post9231842
https://acurazine.com/forums/3g-tl-2004-2008-93/tools-change-bulbs-leds-634337/
Edit: OP, have fun.
Easy for you to say, lol. Those stupid F'n plastic lenses cost like $16 each and, yes, they DO break.
I have put a curse on engineer who designed the vanities. He will rot in Hell for all eternity replacing vanity bulbs on a 3G TL.
The "trick" is get that small screwdriver between the Lens and the Metal Bracket and push the Lens clip in, then pull down. The clip is on the side closest to the center of the car.
Edit: OP, have fun.
![rofl](https://acurazine.com/forums/images/smilies/rofl.gif)
brand noob
I've been searching through this thread for help with the vanity lights. It's comforting to know it wasn't just me who disliked these things. I'll keep trying til I bust something up.
mada51589
05-03-2022 08:54 PM
sockr1
10-01-2015 01:31 AM
wusty23jd
09-24-2015 11:41 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
