TypeS headlight conversion question!!
Old Jan 6, 2009 | 03:56 PM
jdmitr22's Avatar
Im doing the TypeS front end on my 06 and i found out the ballasts on an 06 WILL fit on the TypeS headlight...For my fogs i am using a 9006-h8 conversion harness ($25 from innovativewiring)..my only concern now is how to make the turn signal hookup...04-06 uses 7443 and 07-08 uses 1157...any suggestions?
I tried looking for a conversion harness but could not find anything at all. And i tried searching on this forum but the search wouldnt work for me
Old Jan 6, 2009 | 05:40 PM
KB1Spec's Avatar
Just use the same socket as you have on the 06. You dont need to modify it unless you are pretty anal about it. You can fit right into it as long as the rubber ring are snug right into the assemble. It will not fall off while you are driving.
Old Jan 6, 2009 | 05:43 PM
jdmitr22's Avatar
yea i just dont want it to fall off while im driving lol
Old Jan 10, 2009 | 01:47 PM
jdmitr22's Avatar
any other input?
Old Jan 10, 2009 | 10:07 PM
rockyfeller's Avatar
King of NYC
It's not the 06 ballast that has the problem of compatibility. It is the 04-05 ones that are different. That signal bulb harness is a problem. I tried many different ideas and couldn't come up with one that works.
Old Jan 11, 2009 | 02:51 AM
daniel123588's Avatar
Im probably mistaken, but why dont you just buy an 1157 bulb socket and just solder and rewire the ground, parking, turn signal wire?
Old Jan 11, 2009 | 03:08 AM
Elegant TYPE S's Avatar
Being an Acha Bacha in
Out of curiosity how much did you get the headlights for? I'm relieved that the 06 Ballasts work. One less thing to worry about. And to those wondering about my SN, it was created when I had a 2nd Gen Type S.
Old Jan 11, 2009 | 08:35 AM
jguerra23's Avatar
Looking for new mods
I agree. I did a type-s swap with base 07.......at the same time we swap the harness as well.
Old Jan 11, 2009 | 09:55 AM
Tripnbeats's Avatar
or u can shave the lil notchs down accordingly and make it fit properly on the socket not the mounting base of the headlight....goodluck either way....dremel witht he plastic cutting tool piece on it.
Old Jan 11, 2009 | 10:52 AM
jdmitr22's Avatar
i guess i can hit up advance auto for the socket?
Old Jan 11, 2009 | 11:27 PM
jdmitr22's Avatar
I went to advance auto today and could not find the 1157 socket with pigtail...can someone refer me to one online or a location that has it? the car is pretty much waiting on this last piece!!!!!
Old Jan 12, 2009 | 08:08 AM
Tripnbeats's Avatar
i really dont think u can find the socket loosely like that.
Old Jan 12, 2009 | 05:36 PM
jdmitr22's Avatar
yea the socket exploration failed...
Old Jan 12, 2009 | 05:44 PM
try asking the dealer ship for the harness? Might probably cost more than expected though...Im sure that they sell the 1157 socket seperately as well, this route will require some connectors you will have to find to connect to the pins of the socket.(I could be wrong, i dont know what the end of the 1157 socket looks like where the harness connects).
Old Jan 12, 2009 | 05:58 PM
jdmitr22's Avatar
someone suggested to get #16 from here:
http://www.acuraoemparts.com/delray/...14sep4_b08.gif.
but then i dont how if that would plug directly in the 04-06 harness? Also i looked on Delray's site and there is different part #s between 07 and 08 type S's..
Old Apr 24, 2009 | 08:39 PM
THTL's Avatar
I have an 05 TL and i want to do the type-s headlight conversion. Will it work with my ballast, and any solution on the 1157 socket?
thanks.
Old Apr 24, 2009 | 09:41 PM
You can buy the sockets from www.acuraoemparts.com and you will need 06+ ballasts to make it work. Chinaman is selling a set in the BM.. PM him.
Old Apr 25, 2009 | 06:46 PM
THTL's Avatar
thanks for the response.
Old May 3, 2009 | 07:33 PM
Maddizm's Avatar
sooo... if you do this conversion what do you do with the DRL? What are they hooked up to? Or can you throw some other HIDs? Or foglights in there? I'm a headlight newb... sorry.
Old May 3, 2009 | 07:50 PM
jguerra23's Avatar
Dont put the fog lights .. it will melt the shroud.
Old May 3, 2009 | 08:57 PM
Maddizm's Avatar
^ really? So I have no choice but to go with the lower fogs? I have an 06... so I havne't done any 'accord-fog-mod' or anything like that. So if I decide to just change the whole front to a Type-S front with lower fogs. I guess my current fog power supply can go to those right? Then, what do I wire the DRL's too since the 06 doesn't have them?
Old May 3, 2009 | 09:55 PM
jguerra23's Avatar
^^^ you may want to look into the DRL module they have....KP
Old May 4, 2009 | 04:40 AM
THTL's Avatar
I have this http://www.autobarn.net/des20013.html in my 05.
tman570
Jun 11, 2019 07:56 AM
HondoGermany
23
Jan 8, 2016 03:01 PM
JnC
Sep 11, 2015 06:06 AM
Glorygang600
Sep 5, 2015 01:17 AM
voigt
Sep 2, 2015 10:44 PM
