Type S brake pads
Old Apr 13, 2015 | 07:17 PM
zubi23's Avatar
Type S brake pads
need some brakes, i checked tirerack, it doesn't look like they have OEM which is what I want to go with. Do OEMs have a certain name or part number? I looked up other threads all the links are no longer working. if anyone can send me a link to brakepads for type s that would be awesome. either that or i'm just going to have to buy it from the dealer :/
Old Apr 13, 2015 | 07:21 PM
the reason why I switched from OEM is because I couldnt take the dusting any more!
I'd literally wash my car and not even a 2 minute drive would result in MAJOR brake dust all over my freshly cleaned wheels.
I went ceramic and never looked back!
I enjoy the autozone Duralast cmax gold pads!
they are so much better than the OEM pad in terms of dust.
and i couldnt tell the difference in stopping power either.
as stopping power is more of your tires and traction that pads.
Old Apr 13, 2015 | 07:24 PM
zubi23's Avatar
i haven't had any problems with dusting on my current ones... where can i get some oems?
Old Apr 13, 2015 | 07:29 PM
oem front type-s pad part # 45022-SEP-A60 cost $225 from the dealer.
Delray Acura - Online Acura Parts Store sells them for $169
DCG = $49.99
I dont understand why you want to spend close to $250 which you can only get from the dealer, Zubi...
Old Apr 13, 2015 | 07:30 PM
zubi23's Avatar
tirerack has a lot of options, what should I go with?
Old Apr 13, 2015 | 07:32 PM
zubi23's Avatar
this site has it for 60 bucks for oems...not sure if its legit tho
07 2007 Acura TL Brake Pad Set - Brake - ATE, Advics, Akebono, Beck Arnley, Bendix, Brembo, Centric, EBC, Genuine, Hawk, Monroe, NPN, Nissin, PBR, Top Stop, Wagner, Front, Rear - PartsGeek
whatever options they have.
seriously, they all do the same shit.
Ceramic pads
-less dusting
Carbon pads
-More dusting
Get them!
Old Apr 13, 2015 | 07:33 PM
zubi23's Avatar
aren't the OEM ones ceramic
Old Apr 13, 2015 | 07:42 PM
I dont know what material or compound the OEM's are made of.
Old Apr 13, 2015 | 07:51 PM
zubi23's Avatar
Get them!
are they the right ones? why are they red?
Old Apr 13, 2015 | 07:57 PM
zubi23's Avatar
http://www.tirerack.com/brakes/brake...ModClar=Type-S
found um at tirerack 69 bucks
Old Apr 13, 2015 | 07:59 PM
the red part is just a metal shim.
it could be any color, most other brake pads leave the metal shim unpainted and shiny.
so the brembo pads had an extra step in assembly. painting the metal shims red. which translates into extra material cost and more labor intensive which = pricer pad.
Look at you!
MY baby all growed up!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Apr 13, 2015 | 11:15 PM
MarcoNorthPolo's Avatar
KCCO
Zubi, OEM do make a lot of dust. Going with something with less dust is what I would suggest. They don't have to be expensive, anything that will fit your BBK will do you unless you're tracking your car or extremely hard on your brakes.
Old Apr 14, 2015 | 12:19 AM
Oh Sickest TL's Avatar
Jeff
nova scotia?? howdy neighbour I'm over here in New Brunswick.
Old Apr 14, 2015 | 08:05 AM
Jackass's Avatar
You sure you have OEM pads? If you aren't having dusting problems, you probably don't have OEM pads.
I felt a difference in the initial bite when I switched, but overall functionality was similar enough. No matter what, it was nice to longer have front wheels that were excessively darker than my rear wheels the next day after washing my car. Also was nice to no longer have to listen to my brakes squeal as I backed out of the garage every morning.
Old Apr 14, 2015 | 11:29 AM
ExcelerateRep's Avatar
Former Sponsor
The Stoptech Street Performance pads are designed to dust less than most aftermarket pads and offer increased braking performance. We recommend these whether you are daily driving or doing some performance driving.
StopTech Brake Pads - Street Performance - Excelerate Performance - Japanese and European Performance Specialists!!
Old Apr 14, 2015 | 11:50 AM
KCCO
Well hello to you too!
Old Apr 16, 2015 | 08:05 AM
DMZ's Avatar
DMZ
Head a da Family
I use the Wagner Thermo-Quiet Pads. They're Semi-Metallic, practically no dust, more than adequate stopping power, and only about $25 for the set from Rockauto.
Old Apr 17, 2015 | 08:37 AM
94eg!'s Avatar
#1 Super Guy!
It's nice that Brembo is finally supporting the aftermarket a little better these days. The OEM/Honda/Brembo pads used to be a minimum of $120 for the set (w/ shims & grease).
The red shims on the Aftermarket brembos looks like a different (newer?) design vs the ones on the OEM pads. The OEM ones were re-designed specifically to reduce noise problems typically associated with Brembo's high performance calipers. For $60, I would give red-shim pads a try. Just expect mucho brake dust...
Old Apr 18, 2015 | 02:26 AM
Eaglesfan9106's Avatar
I've recently switched to hawk z code they're great. Almost no dusting and they bite very well. I bought em from endlessrpm.com check it out they have a couple options can't go wrong with any of em
mada51589
Jan 9, 2025 04:40 PM
HOWELLiNC
Oct 19, 2015 03:26 PM
HOWELLiNC
Sep 10, 2015 01:39 PM
mav888
1G RDX (2007-2012)
Sep 8, 2015 11:49 AM
nishant11
Sep 2, 2015 10:34 AM
