Turn Signal LED's?
Turn Signal LED's?
Ok I searched for a good half hour last night and couldnt find any turn signal LED's (ToWERS) for the rear or the fronts that would fit without any slight housing modifcation. Should I assume they dont exist or do they and I missed it?
Ne one with info please help.. thanx! Getting my lights cleared next week and figured would be the best time to do it.
OMGWTF4THGENTL
Any of the 7443 towers will fit without modifaction. The ONLY led bulb I've seen that won;t fit is the autolumination switchbacks... and you have to widen the hole to make em fit.
Post a link to which ones you're considering, I'll tell you if it'll fit.
TheWander... You wouldn't get firtehr that 10 miles around Northern VA with blue led running lights. Popo don't take kindly to folks sporting blue lights other than cops. I'll see you pulled over on the side of the road.
'13 Hyundai Sonata
Originally Posted by RBP_04TL
is there a DIY for the load resistor im not sure how 2 install that
Think these would work very well? I know they'll fit but will they be bright enough?
http://autolumination.com/7443_7440.htm
About 1/2 way down the page.
7443 OR 7440 36 leds (12 forward facing + 24 side facing leds)
INTRODUCING THE WEDGE MATRIX III LED BULB
FOR MORE INFORMATION ON WHAT MAKES THE MATRIX IILED SO SPECIAL
6-SPEED LOVER
I was about to buy those today, but I read that a resistor is needed with LEDs. Is a resistor needed with these LEDs as well?
The Golden One
Originally Posted by sunny201
I think you need resistors for all singal LEDs
A J35A8 EG civic is in
Originally Posted by stavebomb
ok. Do any of you guys know how to wire them up?
The Golden One
Stave...make sure turn signals other than amber are even allowed in your municipality. If it's not, I wouldn't go for it. I would just do the side markers at that point, which most likely will not require any resistors and should just be plug n play.
King of NYC
yeah, i am talking about the resistor. i have no knowledge when it comes to resistors, so bare with me. can anybody walk me through installing these guys?
![](http://www.eatools.com/~luke/hid-lights/resistor-diagram.jpg)
Remember these will get very hot so DON'T let them dangle around and melt other wires and don't cover them. The sinks need air circulation. Don't mount them to any plastic parts. Screw them into a metal part of the car so it will allow better dissipation of the heat.
Rockyfeller, I cleared out my headlights in the summer and put in LEDs. They hyperflash. I have the resistors but dont want to take off my bumper to put them in because I think its too much work for it. This weekend im going to be switching out my tails, do you think I can wire them up to the signals back there to get them to flash correctly again? or do I have to splice it into the front signals?
King of NYC
He's right you can wire them in for the fronts through the wheel well....Though you will need good lighting and have to move the wheel to and fro. Trying to mount them will be a challenge. If anyone is trying to use the solder method to get switchbacks in you HAVE to remove the headlight.
For the rear, easy man, just pull back the carpet and get in your trunk or lay on your back. I used the solder plastic-melt method to get my rear LEDs in WITHOUT removing my tail-lights. I just lay on my back in the trunk. Good ab workout, lol!
Originally Posted by TheWanderer316
![](http://i63.photobucket.com/albums/h136/The_Wanderer316/TL30.jpg)
No modification needed
Just search ebay, they have them cheap, and dont forget to get resistors.
![Drool](https://acurazine.com/forums/images/smilies/drool.gif)
would these only fit typ-s'? You have to explain exactly how I can do this!
Well I put in angel eyes and the wires are wrapped tightly so they dont move and in order for me to put the resistor on I would have to get behind there. Thats why i was wondering if I were to put in the resistors in the back turn signals, would they stop the hyper flashing caused by the leds in the front?
Originally Posted by rockyfeller
No stress with the resistors guys! Just buy the 6ohm 50Watt ones at each light and splice one wire of the resistor to the ground wire (negative) and the other wire from the resistor to the power wire (positive). The resistor will now be taking the load and the LED will work at the correct flasher rate.
wow, im retarded. i didnt even see this post. i just bought amber bulbs... looks like il be returning them!
oh, one question though. i remember reading somewhere that we can use either the 7443 or 7440, which ones should i order in leds? and how do i know which way to wire the resistors?
what i meant is, does anybody know which wire is which in the group that goes to the corner lights.
oh and i bought amber bulbs from silverbulbs.com and they are terrible...
