Trouble Starting
Old Jun 15, 2023 | 10:16 PM
MASS 08 TL's Avatar
Trouble Starting
Hey All,
My 2007 TL with 275k miles on it is having trouble starting.
Has been starting fine but it all of the sudden didn't start. I turn the key on and I have das lights, radio and nav all working. I tried it 7 or so times and than the last time it starts up no problem.
I drove it home (about a mile) and turn it off and try to start it again and nothing. It started just fine the 2nd time.
It started just fine when i started it every hour for the next 3 hours.
Anyone have any ideas?
Also this is the firsy time I let the gas go below a quarter in years.
Thanks for the help
Old Jun 16, 2023 | 11:20 AM
twokexlv6coupe's Avatar
Check all your battery cables and terminals, especially the ground cable(s).
Old Jun 16, 2023 | 12:06 PM
MASS 08 TL's Avatar
I checked all those and all good.
It has started up just fine today but I have only drove it 3 or so miles.
The battery is pretty old so I am going to replace that and hopefully works well.
Thanks for the advice.
Old Jun 16, 2023 | 03:20 PM
Superunknown's Avatar
Double check the starter ground. It can look connected when it isn't.
Old Jun 17, 2023 | 09:41 AM
PhilB81's Avatar
I had a similar problem, I ended up getting a new starter.
Old Jun 17, 2023 | 12:51 PM
NBP04TL4ME's Avatar
Stay Out Of the Left Lane
The battery cables have been known to internally corrode without showing any signs of such - other than starting problems. Run your hands along the cables squeezing them to see if they collapse or stay rigid.
Old Jun 18, 2023 | 06:01 AM
BillMFD3's Avatar
I had similar symptoms at 250k
it was the starter
Old Jun 18, 2023 | 07:47 PM
PhilB81's Avatar
I forgot to mention that I was at 110k miles or so when I had this issue (approx 2-3 years ago). Our TL isn’t used for long drives though, so I suspect years and engine start counts is far more of a factor than mileage.
Old Jun 18, 2023 | 08:02 PM
NBP04TL4ME's Avatar
Believe that makes sense.
Old Jun 19, 2023 | 07:29 PM
csmeance's Avatar
sounds like the starter or starter relay may be on it's way out
Old Jun 20, 2023 | 01:47 PM
MASS 08 TL's Avatar
Thanks all.
I am going to replace the battery first since it is due and check the starter relay and than starter.
Thanks all for the help.
Mason Ambery
Nov 27, 2019 04:55 PM
DMZ
Nov 5, 2018 03:24 PM
smoger
May 5, 2010 11:46 PM
Teknikscian
Jul 12, 2009 10:28 PM
GenXET
2G CL Problems & Fixes
Jun 23, 2006 08:50 PM
