starting problem
Old May 16, 2006 | 10:24 AM
GenXET's Avatar
starting problem
My car seems to have some starting problem. Like it won't start sometimes, it will crank and you hear the "ta ta ta" noise... but the engine won't start. If you let it sit for like 5 mins, then start again, it will start normal. What could be wrong with it?
I checked the battery, and it was good. All my interior lights / radio turn on when I turn key.
Old May 17, 2006 | 09:14 PM
red01cl-s's Avatar
Sounds very similar to what happened to me. When the problem happens, is it hot outside? If so, it's probably you efi relay.
Old May 17, 2006 | 11:12 PM
AegeanCl's Avatar
It could be a few things. Have you checked your alternator, that could be on its way out.
Old May 18, 2006 | 02:48 AM
GenXET's Avatar
it happened both in hot and cold days.. but lately its been worse and worse as in before it only happen once a month, now its like couple times a week.
Old May 18, 2006 | 02:49 AM
GenXET's Avatar
but my interior lights, music from radio and everything are on
Old Jun 14, 2006 | 07:54 AM
Nicks07018's Avatar
6th Gear
Same thing happened to me. It was because of the winter fuel addatives. I had to get a new feul regulator and computer.
Old Jun 23, 2006 | 08:50 PM
manitou's Avatar
Has anyone found a fix for this problem. I am now having the same difficulty. 03 cls 6speed 65,000 miles. Acura dealer has replaced battery, & starter. Problem persists. HELP!
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
obert
Dec 14, 2015 11:36 PM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
jordanboi
Sep 5, 2015 01:33 AM
NSolace
Sep 3, 2015 08:02 PM
