Transmission fluid via cooler hose
I'm aware of the 3x3 method and that's what I've done last time (30k) ago.
I was just taking to a friend and he said that there's a better way that not many people know about, except mechanics:
Has anyone heard about this? Is it better than the 3x3 method?
To replace the transmission fluid, you unplug the cooler hose going from transmission to radiator and start pouring new transmission fluid from the top until the transmission fluid going out is clean.
Based on what I have read here on AZ, I would do the cooling line method. Since you did a full 3x3 30k miles ago, you won't be shocking your system ( I don't think) with all brand new fluid.
Registered Bunny
My question to you is why you would do that though? There's technically the very faint risk of not pouring fast enough and running it dry. I don't really see the upside unless you're in a rush?
The discharge fluid transitions from old brown fluid to bright red in just a few seconds. It's obvious when you've gotten the old fluid out. Fastest most efficient way of getting 100% new fluid in
There's also the risk of overfilling it as well.
SidhuSaaB
05-30-2020 12:40 AM
lanechanger
10-13-2015 10:56 AM
