Transmission fluid on 20k
I went to Acura delaership for the B1 services on my 06 Acura TL. My car has 21000 miles on it when it was services. As soon as the service is done, there is a note saying that the transmission fluid is dark and needs to be flush for $ 224 or drain and refill it for $101...
I was like surprised because my TL only has 21000 miles on it and it needs transmission fluid change? Does anyone ever had this before????
When does the transmission fluid need to be flushed?? At what mileage??
I'm assuming you are talking about an Automatic Transmission - The service dept. at Acura of Tempe is recommending the transmission service as part of a 30,000 mile service. My car has about 25K miles on it and I went ahead and had this service done. People here will probably say I wasted money, but I'd rather be safe with this.
Originally Posted by Black0ut
What are your opinions on Synthetic ATF? I'm thinking about doing it on my 04...
Yes, it is an automatic transmission. Sorry forgot to mention it....
Thank you for the info. I will probably drain and refill it when it gets 25,000 miles on my car. I was thinking that usually the transmission fluid needs to be changed by 50,000 miles.
Never heard about it though. Is that what Acura dealer recommend you for your transmission fluid??
Typical dealership...
Greetings dre23, I say the above due to there actually being a tech letter/bulletin of sorts that Acura put out literally stating that the auto trans fluid gets dark extremely quick and that it was "normal." Not an indication of trans issues nor a reason to have the trans serviced "now."
If they mentioned a foul / burnt odor, that would be different...
If I remember correctly the TL manual calls for the first change at 60K. I'm a firm believer in every 25 or 30K. I would wait until your next oil change and then definitely consider it. However, read your owners manual on how Acura recommends it is done: drain and refill at least 3 times to ensure the fluid is near completely flushed etc.. Your $101 drain and fill price above is just one of the three required. The flush isn't something Acura recommends either but given the right machine/process that can be a perfect alternative to the 3 times drain and refill.
Then again, for about $120 you can do it yourself. No different than changing your own oil if you have ever done that.
So you would say that change the fluid every 25 - 30k ??
Thanks..
Do you know what kind of oil they use??
I know Castrol has an "Multi Vehicle Import Blend" that says it meets Honda ZF specifications. There are others as well too. I think Amsoil claims that too. Not sure, just have to read the label.
I have never done an oil change but, if I can find the directions in how to change the transmission fluid, I can probably get it done myself. Do you know if there is a thread regarding how to change the transmission fluid?? Do you know what kind of oil they use??
Thanks..
Thanks..
I am a gen2 owner, and your trans is the offspring of our constantly failing units.
I notice yours fail ever sooner than ours- at least I got 68k out of my 1st one, full warranty to 7 years/109 k miles- ordered by the court- you gen3s need to get a class action going soon
The book says 60- but read the fine print about SEVERE driving- such as living on Earth
Note on terms used- acura will say trans flush- meaning manually drain and refill 3 times.
Quickie shops use the word flush to mean a machine hooked up and exchanging fluid while it runs.
Thats NEVER to be done to your TL or kiss that trans goodbye
Read gen2 threads and do the 3x3 ~flush~ NOT JUST DRAIN 3 ADD 3 AND CALL IT GOOD
The trans holds over 7 qts but only gives up 3 qts at a time, you drain 3 add 3 drive 5 minutes- drain 3 add 3 drive 5 minutes drain 3 add 3 done. Thats as good washing out and refilling fresh fluid as you can do.
Its easier than oil change because no filter to deal with
USE ONLY HONDA ZR1 ATF honda dealer (cheaper than acura dealer, same exact stuff) or some private owned import parts store carry it.
Our cars are very picky and honda makes fluids designed for their special needs
Yeah, the dealer said they use some machine made by B&G to do the flush and its $280...i'm really stumped as to what to do. I'm afraid to take it anywhere else and i'd rather have the dealer responsible if anything f*cks up.
DO NOT USE A MACHINE- Did I say that loud enough ???
A dealer using one is very odd- read the owner book for method 3x3
A drive thru oil change place that will use your fluid is better than that!
As long as they drain 3 add 3 and you pull out and around the block a few times to push out fluid from deep parts of the trans- then back into the bay and drain again
that would be ok
The dealer charges so much because they dont use a drive thru- a tech has to put it on the lift and that take valuable time.
Or invest in a few tools for less overall cost and do it right yourself.
After that, you wont want anyone else touching your car- its too simple to do at home~
that would be ok
that would be ok
that would be ok
I too use to claim all "flush" machines are bad for Acura, especially the the ones we use to have at the dealership I worked at. Several of the new machines work just fine with the TL and are most likely what the dealership utilizes and has mother Acura's blessing. (Truth be told however, who knows)
Anyway, several of the machines do not actually "pressure flush" the trans - that is what Acura does not want. Rather these machines, simply by the pressure/suction of the trans itself while the engine is running, gather the old oil and then allow new oil/fluid from a second reservoir to be pulled in. They are very effective, non wasteful and give you a near one for one quart swap (not "flush").
Two issues I don't like with them: The typical steep price like the mentioned $230 -$280 above, and the fact they must tap into the trans cooling lines some where. This in turn can introduce both a future leak and or crap into the trans etc..
So, even though you waste a bit of fluid, for about $10 a quart for the Honda ZF you do it yourself - the right way. I used 12 total and a 4 drain and fill process. Actually did it every day after work for 3 days. No you don't need that many miles between fills yet it doesn't hurt either.
Cheers
The second problem with flushes is that the magnetic drain plug is not cleaned. If you've ever removed the magnetic drain plug on a Honda at the first fluid change, you'll be shocked at the amount of clutch material that you'll find on the magnet. However at subsequent changes, you'll find very little material on there.
2. Flush will not kill the transmission as long as they don't dump some kind of ex-lax transmission cleaner in there. Even then, I've never seen any evidence of one being linked directly to a transmission failure. It's more hearsay than truth. The bigger problem with a flush is that the magnetic drain plug is not cleaned.
3. Z1 fluid is probably the safest choice for some, but my source at a major OEM is telling me that the Z1 fluid really isn't as great as Honda wants us to think. But I should save that info for another thread.
4. Again, Honda does NOT say that the quadruple (or triple) drain and refill method is necessary for regularly scheduled maintenance. The manual clearly states that the procedure is only need if the transmission was contaminated with the incorrect fluid. The procedure in the factory service manual for a normal transmission service only describes a single drain and refill. I do, however, believe that the multiple drain and refill method is better and will give you better shifting. It isn't absolutely necessary though, according to Honda. But for the sake of accuracy to other forum members and our visitors, I think that we should separate our personal beliefs and the official info from Honda.
I think the book maitenance schedule is a bs scam run on govt regulation much like CAFE fuel results!
Most cars need stuff a lot sooner- the govt said "make your cars need less maitenance"- ok thats easy- lengthen the intervals and then make severe service the norm
"Make them get better mileage based on our funky test procedure"-
OK use 5-20 oil and that will give a tiny bit more fuel economy- who cares about engine life
I admit to not knowing current machines and all the honda TSB that are floating around
All I know is the babies get warm when driven spirited and changing the fluid is not going to hurt anything. I do feel a full change out is superior to a 3 qts dilution of 7 quarts of the old stuff
You wouldnt change 2 qts of engine oil or brush/floss half your teeth would you?
I also think acura says drive 5 minutes between drains as that is pushing new fluid into the torque convertor and old fluid towards the pan to be drained out and refreshed. No need to mix the oils- just get rid of the stuff. I admit to little knowledge of the internal pressure systems of the transmission, just what I read and reckon~
Also, remember that when you change your engine oil you don't change out 100% of it either. Look at the difference between capacity at oil change and at engine overhaul.
I learned early on that the maintenance schedules and recommendations were more of a marketing/fuel mileage ploy than anything else.
Screw 5-20 oil. I went to 30wt right away because I don't believe in giving up engine life to get that extra .5mpg. I'm sure the 5-20 will get you through the warranty period and beyond just fine. But what if you get it too hot, what if you get a lot of fuel dilution, what if you have the common pinging issues? Think about oil film thickness and what happens if you get a piece of dirt thicker than the oil film. A good quality 30wt will give you more room for error with no downsides unless those of us that paid nearly $40K for a car can't afford the extra $.05 it costs between fillups. Look at the same car sold in Europe. 10-40 is an acceptable oil for these cars.
Same with the trans. 120,000 miles? That's completely insane. Z1 fluid has been proven with VOA results that it's nothing special and not even synthetic. I wouldn't think about taking even a full synthetic to that interval. I switched to synthetic on my first 30K 3X drain and fill, added a cooler and a real filter, and do a 1X drain and fill at every oil change.
Another point is these cars close the throttles on shifts so you really don't have to worry about harsh shifts when going with a different fluid like older Honda products. I'm running a fluid that is not recommended in a Honda which is Amsoil ATD, their heavy duty Allison fluid. I picked it because besides being a full synthetic, it doesn't have any VIIs which should work very well since the fluid is shared with the diff. This is probably one of the few setups that could truly go 100,000 miles without a service.
Originally Posted by SodaLuvr
20wt oils are more shear stable than the 30wts anyway. There are many Crown Vics and other Ford delivery vans running the 5w-20 with no problems. Many of these have over 200k miles and have no excessive engine wear. You should know this from BITOG. It's more of an availability issue in Europe anyway.
Agreed for the most part. That's why I said a good quality 30wt. You could get a cheap 5-30 and have it shear down less than a 20wt. It's also the reason my particular 30wt of choice is the ACD straight 30 with no VIIs. The TL seems to love it and I'm going to do another UOA on it which I will post. I find it funny that a 10-40 is acceptable over there but over here your engine will blow up if you use it lol.
5-20 is fine for normal use and especially people with a very short daily commute but I would not want to even think about continuous hard driving on the thin stuff. And again, my main reason is that it gives better "insurance" assuming it's a quality product. The police cruisers make no power and what little power they make is spread out over 8 cylinders.
Synthetic or dino isn't the problem with Z1. It's the additive package that's a concern.
I partially agree. Z1 is heavily friction modified as you know. That's the reason people complain about harsh shifts when switching to other brands. With the drive by wire throttle it's not an issue and using the "unrecommended' thicker ATD would definately cause harsh shifts in the old units.
IF you're going to use Amsoil, use the ATF not the ATD. The ATF was designed to meet Dexron-VI specifications and should perform better, period. Transynd is an older Dexron-III(G) based product that is unlikely to pass the more rigorous friction tests of VI. The VI is also more shear stable than any Dexron III type product.
I would also recommend the ATF over the ATD to anyone wanting to use Amsoil based solely on the fact that it hasn't been tested in our transmissions. I actually PM'd back and forth with a couple of the Amsoil guys over at Bob and while they couldn't recommend it on the board, one of them thought it would work great in the Honda AT as long as shift quality doesn't suffer.
The ATD doesn't use any VIIs so it should be very shear stable. The shifts are quicker and snappier but they can't be felt. For what it's worth I started with the ATF and really liked it but since my car spends summers in Vegas and Phoenix I thought I would try the ATD for a while.
Take this with a grain of salt since I tend to be OCD but I stand by my belief that the 5-20 is for CAFE ratings only and that a 120,000 mile transmission service on a regular fluid is insane.
MY 01 owner book specifically says drive 15 minutes to warm
drain-refill Drive 5 minutes-drain refill etc
The 5 minutes is stated
I dont know if its in the online book
https://techinfo.honda.com/rjanisis/...01_OMANUAL.asp
I bow to the working scientific oil knowledge of certain members
If this next replacement trans gets more than 12k on it, I will switch to a synthetic and see how it feels
For the engine I run 5-30 all year- west coast weather- Fully Synthetic of course- and when I get around to sending in the last sample, I will decide which brand to stay with or switch
Note that it says to "flush" the transmission, follow the procedure. In the owner's manual, no where does it say to flush the transmission as part of the normal service procedure.
It's not the highly friction modified that's the problem. It's the friction level which plummets not long after installation that raises concerns about clutch wear.
The Z1 or synthetic? It's my thinking that something with a little less friction modifier coupled with the DBW throttle would be good for less clutch wear. For the other people reading this, friction modified fluid is usually "slipperier". That's why I think the ATD will do a good job and the shift quickness is noticable. I'm not recommending something like the Type-F. I believe there is a line you cross where not enough FM would be a problem too.
The concern is with the frictional properties. Dexron-VI fluids will have a more stable frictional level during the life of the fluid and have a more consistent shift feel.
I will send Pablo a PM to see what his opinion is on the ATD in regards to this as I really don't know. From the literature, the oxidation level is supposed to be really low. I can tell you I haven't seen a change since the first installation but I do a drain and refill at least every 10K so I'm not really giving it an opportunity. I've got a blackstone test kit so I'll get my first UOA on the next drain. If it looks good I'll probably double the interval and see what happens.
Originally Posted by Simba91102
OK boys, put em back in your pants. Bottom line seems to be (to me anyway) that Honda can recommend pretty much anything they want for service/maintenance, so why would they recommend a product that won't provide the best protection and performance?
My point with the 5-20 is that it's recommended for CAFE fuel economy standards which the rest of the world doesn't have. If Honda can get every car they sell to get .5mpg better mileage and they sell 500,000 cars, this is very beneficial for them.
The UK recommends a thicker oil and they don't have CAFE telling them what to do. Oil availability isn't an issue there like the some other nations over there.
5-20 is ok for "normal" service, it just leaves no margin for error IMO for when things get heated or things go wrong.
SodaLuvr does bring up a good point. A 5-20 oil is very shear stable. If you take an identical 5-30, it's possible it could shear to a 5-20 over time. A lot of the time but not all the time with oils with a higher numerical spread like a 5-50, there's more of a chance that it will shear to a lower weight with high temperature and load. Not always true but it does happen and Mobil 1 is notorious for this.
The reason I use the straight 30wt synthetic is that it flows good enough cold to be considered a 10-30 but it has no VIIs so this stuff will never shear down. The space that is usually taken by the VIIs is replaced with more actual oil. It's a very robust oil and has shown excellent wear results. The TL seems to love it. If anything the car feels quicker with it and contrary to popular belief, the oil pressure light goes out just as quick if not quicker when I start it in the morning. I live in Cali where I can get away with this. It might not be the best idea in extremely cold climates.
No, oil availability is an issue there for weights such as 5w-20. How many Euro manufacturers use a low HT/HS oil?
As you know most Euro manufacturers use a higher HTHS oil which reinforces my belief that CAFE pushes US automakers into recommending the thin stuff. While the climate is generally milder in the summer than a place like Phonenix or Vegas, they still use a thicker oil. Some of it is driving style, I'm sure. In Greece, everyone thought they were a rally driver and drove accordingly. My ACD has an HTHS of 3.4 which is pretty good but not too thick either.
I've run the 5-20, 5-30, 0-30, and 30 in the TL and have yet to notice a decrease in fuel economy, slower cranking, or an increase in time to get full pressure. In fact pressure seems to come up quicker with the 30wt which brings me to another point... The thin stuff pumps easier so it theoretically should get to moving parts quicker. But, the thick stuff stays in bearings and valvetrain parts while the engine is off and can potentially offer better startup protection before the pressure arrives.
Maybe in 200,000 miles and a few years from now we can revive these posts to see who's right lol.
Also, look at the # of long-drain 5w-20 products on the market. The service intervals in Porsche, BMW, etc vehicles tend to be very long and few 5w-20s are up to that task. In addition, some of the Euro applications have engine designs that truly need the higher viscosity oil.
SidhuSaaB
May 30, 2020 12:40 AM
