Tinting TL
Old Jul 13, 2010 | 01:11 PM
raf1919's Avatar
Tinting TL
i talked to a shop about tining my windows, was told that for TL the window guides need to have felt put on them so it wont scratch tint. They will need to take about door panels (additional charge).
can anyone comment on that? i have never heard of that being needed.
Old Jul 13, 2010 | 01:14 PM
Mole skin ftw.
if you don't get the mole skin.....the tl will scratch your tint.
Old Jul 13, 2010 | 01:25 PM
ajs800's Avatar
I am about to do this myself and I plan to install the moleskin to be safe. Some places will say it's not needed, which might be true, but it's cheap insurance.
Old Jul 13, 2010 | 01:30 PM
spicynoodle116's Avatar
Newb
I was quoted $20 additional for EACH window, and I'd have to supply my own. Fck d@. My tint was already $240, dont wanna spend $80+ more.
Find new tint shops.....
Old Jul 13, 2010 | 01:31 PM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
Confirmed. For our cars, it is DEFINITELY needed.
Old Jul 13, 2010 | 01:45 PM
raf1919's Avatar
is there DIY how hard is it to do it?
Old Jul 13, 2010 | 01:46 PM
Someone else should answer this. I've never done it.
Old Jul 13, 2010 | 02:19 PM
dadon's Avatar
there is a DIY in garage somewhere i think???im to lazy to search right now..lol
Old Jul 13, 2010 | 02:34 PM
Waltah's Avatar
no moleskin here and no scratches either
Old Jul 13, 2010 | 02:47 PM
AMUA6's Avatar
ScoobyZINE
+1. I always wipe down the rubber seal on the door panel that touches the window every time I wash the car. Not sure if this helps any or not, but seems to work for me
Old Jul 13, 2010 | 03:25 PM
Crestwood1001's Avatar
I had it added for 20 for all the windows. Only cost me 200 to have all my windows tinted. They also did not need to pull the door panels, they just pulled the weather stripping and installed it.
Old Jul 13, 2010 | 04:14 PM
guitarplayer16's Avatar
DIY:
http://www.acuraclubsa.com/DIY/moleskindiy.htm
Props to the guy who made it.
Old Jul 13, 2010 | 04:37 PM
dwb993's Avatar
Thats a great DIY---this job is not too difficult.
A few notes:
1) Be careful with the screw on the bottom rear of the front door panels with the rubber grommet. This screw is known to strip easily and is a pain when it does. If yours is not already stripped from the factory, take care that you don't strip it.
2) There is an alternate method that does not require removing the whole door panel. While many have complained that it damages the upper portion of the panel, it can be done. It did not damage my panels at all.
3) The glue from the moleskin will melt and cause streaks on the windows. Get a can of Goof-Off or Goo-Gone or similar to remove it safely.
4) Purchase kits from tintprotector.com---I believe they are a vendor here on AZ. Mention AZ and get a discount! Search the website for both install methods.
Old Jul 13, 2010 | 04:47 PM
leedogg's Avatar
RAR
check your window blades, did the tint shop cut/trim them back when they installed your tints?
thats a possible 'solution' for some of them.
Old Jul 13, 2010 | 04:56 PM
poormans_tl69's Avatar
CARBON FIBER WDP TL
yea you have to put moleskin.. they do need to remove the panels
Old Jul 13, 2010 | 05:55 PM
rolan04tl's Avatar
3) To avoid Glue streak do the single strip install. That is, instead of cutting the moleskin to fit each blade separately, don't cut it and install the whole strip over both robber blades on each window. Trust me, I had to install the moleskin three times to learn this, but it works!
4) you have the instructions on the link, its a real easy install, save yourself some $ and buy moleskin from empirepao - http://www.empirepao.com/?page=moleskin
They also have links to instructions on how to install on the provided link.
Other than that, I recommend installing moleskin, regardless. I had to replace my tints because I did not know about this. its a must in TL's. after moleskin, no more scratches
Good luck,
Rolan
Old Jul 13, 2010 | 09:02 PM
raf1919's Avatar
so its the rubber that scratches the tints? what is about the TL rubber my last car had rubber there too.
Old Jul 15, 2010 | 02:41 PM
raf1919's Avatar
So the tint shop that did my last car. (they did a really good job) said they Do TLs w/ out moleskin and have no problems. He even told that if it scratches their lifetime warranty will cover. Only downfall they only do metallic tint though.
anyone actually get metallic tint and can confirm if it messes up radio and navi?
Old Jul 15, 2010 | 05:33 PM
Xiomaro's Avatar
1st 3g Turbo TL-S
Originally Posted by amua6
+1. I always wipe down the rubber seal on the door panel that touches the window every time i wash the car. Not sure if this helps any or not, but seems to work for me
+2
Old Jul 16, 2010 | 06:32 PM
crewdog's Avatar
5th Gear
I'd be interested to know if there is a difference between metallic vs. ceramic type of tint and it propensity to scratch without moleskin. I like lifetime warranties, but hate to have the car in the shop.
Old Jul 16, 2010 | 08:33 PM
NAiL05's Avatar
I am running llumar on my car only time will tell without moleskin to see how long it lasts. If anything I just get my buddy to tint it again.
Old Jul 16, 2010 | 09:42 PM
leedogg's Avatar
RAR
its not the rubber, its the dirt that gets trapped by the rubber. We have tighter seals than other cars to keep out wind noise, so any dirt that gets trapped in there is pressed against the window harder.
Old Jul 17, 2010 | 12:17 PM
mrlal8's Avatar
i had my car tinted without mol skin....got fucked up in 1 month
i had it retinted with mol kin and no problems at all....they use double stick tape to keep the mol skin intact so after a few weeks sometimes the glue from the tape gets onto the window from constant rolling up n down but all you need to do is take some rubbing alcohol and clean the tints....eventually the glue is completely dried out and ur windows stay perfect
most tint shops charge 10 dollars per window to add molskin and that includes the material
Jul 16, 2017 07:33 AM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
ITSJESTER
4G TL Photograph Gallery
Oct 13, 2015 12:53 PM
jmaxima03
Sep 27, 2015 10:22 AM
