Tint issue
Old Aug 26, 2008 | 09:46 AM
BackinBlackTL's Avatar
i like it dark
Tint issue
since the new and improved azine, i cant search ANYTHING
so my driver and passenger side tint is starting to look terrible, i have all of these lines (atleast 4 on the driver and 2 on passnger) running up and down the windows, looks like the seal is real tight and scratching the tint or something?? either way it's pissing me off, any suggestions/comments??
Old Aug 26, 2008 | 10:01 AM
Distorted Reality's Avatar
iScrape going into
You are correct about the seal causing the scratches on the tint. HUGE problem with the TL's and alot of newer car's these days. Their is a vendor on here named FLNSX he sells a product called moleskin it is a felt type material that is laid in between the weatherstripping to help/prevent future scratches from occuring HUGE benefit and improvement. Now their are members on here that swear by it including myself, but however their are members here who have never had any problems with tint scratching or doesn't bother them. Your choice.
Old Aug 26, 2008 | 10:08 AM
i like it dark
thanks guy
Old Aug 26, 2008 | 01:02 PM
CarrieLynn's Avatar
Good Info!! Thanks
I have tint and just noticed lines the other day.....
Old Aug 26, 2008 | 01:40 PM
LoveMyTL-S's Avatar
Moleskin is your friend................
Old Aug 26, 2008 | 02:36 PM
JerZDevil's Avatar
My tint looked like I took a steel wool pad up and down the window. I redid everything last month and I have 2 hairline scratches as well. I may invest in the moleskin kit from a vendor here.
http://www.automoleskin.com/groupbuy.htm
Old Aug 26, 2008 | 02:48 PM
dudechewy's Avatar
DuDeChEwY
i ordered the stuff from em couple of days ago and got it yesterday........i just gota find some time to put em on.................i already have a lot of scratches on my windows so im just gona get my windows tinted again
Old Aug 26, 2008 | 05:37 PM
NOTSKERDD's Avatar
I redid my tint last month- if you don't want mole skin, just keep the window opening clean. I use my credit card between a wet rag. So far no scratches.......
Old Aug 26, 2008 | 09:14 PM
jokerman826's Avatar
Jokerman
i have a question about this. what i wa looking at my window i saw two seals.Wouldn't i need this on both seals to preven scratching.
Old Aug 26, 2008 | 10:03 PM
playa4real's Avatar
2 seals? there's only one. its a rubber piece that is closer to the interior of the car. you can pull it out by first rolling ur window down and then prying at the trim towards the inside of the car. it pops off and acts as if there is a hinge holding it in place. once popped off reach in and pull out the black rubber piece..thats the piece u want to apply the moleskin to.
Old Aug 26, 2008 | 10:11 PM
<{Kris}>'s Avatar
My car was tinted when I got it and the tint are moderately scratched up. It doesn't really bother me though, it's absolutely not noticeable from the outside and I can only see it at a certain angle from the inside.
Old Aug 27, 2008 | 12:57 AM
carlos9827's Avatar
2011 BMW 335i
Depending on your relationship with your tint shop you might be able to get a Re-Tint for free. I know I did I simply told them, these wscratches were comon on all 3G TLs and because of this, it was something that tint shops out there should be aware about and inform their customers. Because they never told me about this, a few months after they tinted my windows I had those scratches, I told them if they would have informed me of this prior to me getting my windows done, I would have decided to go with the moleskin. They agreed with me and so I got free re-tint. This may not work for everyone but I figured I would throw it out there, doesn't hurt to try.
Old Aug 27, 2008 | 01:51 AM
J-STEELE's Avatar
ADVANCE.
Yessir, get some moleskin... It's hella easy to put on... Hopefully your tint shop will redo your tint for free. Just be cool with them and shouldn't have a problem... I had those stupid scratches on my tint, stupid me should of searched this prior to tinting but it was my first tint ever and thought everything would be cool... Anyways, theres like a thread or whatever for acurazine members for discount on the moleskin... Pay a little bit cheaper, thats what me and my bro did. So far its money in the bank with no issues at all... Hope everything works out for ya... PEACE!
Old Aug 28, 2008 | 08:27 PM
Jokerman
After looking today, you are correct there is only one seal, but it does have two lips on it. It has a lower lip and then the upper lip that you can actually see. I notice that dust likes to sit in the crease that is there between them. So since there are two lips, would i be safer to get two kits or should i just do what some people did and cut it in half length-wise and apply it to both seal lips.
Old Aug 29, 2008 | 08:43 AM
dek's Avatar
dek
according to flnsx he recommends cutting the strip in half so that you'd apply it to both strips individually. i have seen a tint shop apply it as a single piece. i'm trying to figure out which way is better so that the moleskin doesn't peel off. i'm also exploring a way to relieve some of the pressure of the weather strip but am uncertain of the consequences.
Old Aug 29, 2008 | 12:54 PM
OffTopik's Avatar
AZINE_FEIGN
I went to the beach last summer and sand that was stuck to my arm got in the window crevice and lets just say i was not a happy camper. just a warning
Old Aug 29, 2008 | 01:31 PM
LoveMyTL-S's Avatar
I applied mine as one strip. I have gotten a little glue on the windows from the adhesive........but it came right off with a little googone. Just an FYI.
Old Aug 29, 2008 | 02:53 PM
dek's Avatar
dek
cool...thanks for the heads up.
Old Sep 1, 2008 | 05:02 PM
Jokerman
so which one am i going to put it on if i only do one lip.
Old Sep 1, 2008 | 09:36 PM
dek's Avatar
dek
you'd apply the moleskin to both of the strips as one piece vs. cutting it in half and applying it to both.
Old Sep 2, 2008 | 08:09 PM
flnsx's Avatar
Tint Protector Discount
Hi all,
Here is the link to the AcuraZine member discount.
http:///forummembers/
If you have any questions I'm here for you!
snorf
Nov 4, 2019 06:44 AM
TLDude876
Dec 28, 2016 03:18 PM
Frathora
Sep 28, 2015 11:29 PM
carz0159
Sep 20, 2015 06:11 PM
