Third brake light mod?
Old Nov 5, 2018 | 09:17 PM
Sadiq786's Avatar
Hey guys, anyone know how to properly install the gs-100a strobe controller for the third brake light? Myself and friend of mine tried installing it, but blew a fuse while in the process. Luckily, I had a spare. Are there any tips or tricks on how to install it? We followed several youtube videos, but no luck. Any help is appreciated.
Old Nov 5, 2018 | 09:21 PM
Midnight Mystery's Avatar
Null and proud of it
Pull fuse or disconnect negative on battery first... Hook it, in line... You may need am external ground... i.e., run a ground from that moduel to a bolt nearby... IDK, it's been a while for me...
Old Nov 5, 2018 | 09:26 PM
Sadiq786's Avatar
Will try that, thanks!
Old Nov 6, 2018 | 08:53 PM
Superunknown's Avatar
Don't add a ground to this. The module just goes in series with the brake light.
I don't like the amount of wire or room you have to work with at the third brake light, so I picked up another light and cannibalized the connectors to make a reversible install.
I'm guessing you've already cut the connectors off. Splice the wires connected to the car (that is, the wires coming out of the headliner) to the input and splice the wires connected to the light to the output. Black to black, red to whatever is left over (should be white/black stripe on the car, green/white stripe on the light).
Old Nov 10, 2018 | 07:06 PM
TL-Syndicate23's Avatar
They look better on the actual tail lights. I have a set and everyone's always asking where I got them installed lol.
Old Nov 11, 2018 | 09:47 AM
Ossman14's Avatar
You should post up a video
Old Nov 12, 2018 | 11:14 PM
Sadiq786's Avatar
Thanks for the help guys, we were able to figure it out. Re-did the wiring and used heat shrink tubing to seal everything up. Video attached, ignore my voice lol.
File Type: mov
Old Nov 12, 2018 | 11:16 PM
Sadiq786's Avatar
Yeah I might do that either before I store it for the winter or next spring, but for now, the third brake light will do.
Old Dec 13, 2019 | 03:29 PM
Michael Johnston's Avatar
so like what fuse was it lmao i had mine working then it just stopped. i’m assuming my fuse blew.
Old Jan 7, 2024 | 06:43 PM
Ohun99's Avatar
6th Gear
Hey guys, was there any resolution here? I had this working for the 3rd brake light and now all of my brake lights are dim. Want to check the fuse as well.
greendestiny
44
Feb 25, 2006 02:38 AM
RelentlessOne
Feb 9, 2005 02:27 PM
jeff5588
Jun 17, 2004 12:10 PM
cor
Sep 9, 2003 06:18 PM
Nugs3
Aug 5, 2002 04:55 PM
