switchback colors
Old Oct 28, 2008 | 01:47 PM
gcoast213's Avatar
blackac
switchback colors
i just had my switchbacks installed in my car and the running lights are yellow instead of white. im thinking it might the orange housing but i saw other tls with the same housing and theirs are white. any suggestions?
Old Oct 28, 2008 | 02:00 PM
jmkiang's Avatar
zaino'd
Did you buy the wrong ones?
Old Oct 28, 2008 | 02:03 PM
gcoast213's Avatar
blackac
switchbacks
they only come in white and amber so i dont think so.
Old Oct 28, 2008 | 02:15 PM
jmkiang's Avatar
zaino'd
Well, it doesn't matter how you insert the switchback... you'll get white running lights either orientation.
If you got switchbacks, then I dunno whats up with them. Ask for an exchange?
Old Oct 28, 2008 | 06:13 PM
MichaelBenz's Avatar
CTS-V Import Slayer
Wrong section...this is hardly performance related....unless I am misunderstanding something here.
Old Oct 28, 2008 | 07:37 PM
ggesq's Avatar
Nope- not missing anything. Thread moved.
Old Oct 28, 2008 | 11:57 PM
rockyfeller's Avatar
King of NYC
Uuuh can I ask a dumb question?....Are your headlights stock? You DO have your lights cleared.....right?
Old Oct 29, 2008 | 12:22 AM
Fulani has a TL's Avatar
That would probably be the reason why
Old Oct 29, 2008 | 05:50 PM
godizus's Avatar
Needs wheels
This is incorrect. If the blade is installed one way it will have white running lights and amber blinkers, but the other way will yield the inverse results. It even says so in the instructions they give. You just need to turn them around and re-insert.
Old Oct 29, 2008 | 06:12 PM
lights's Avatar
Engineer
that's the funniest question i've seen today!!! thanks for your laugh.
just imagine it, switchback LEDs behind the amber diffusers......:lol:
Old Oct 29, 2008 | 08:49 PM
TL1999's Avatar
GO DAWGS!! SICK'EM!!
so did you get your headlight cleared???
here is my cleared headlight w/ switchback light bulb.
Old Oct 29, 2008 | 09:09 PM
jmkiang's Avatar
zaino'd
I installed them both ways and ended up with the same result. Did you try it yourself or are you basing your knowledge on what the instructions told you?
Old Oct 29, 2008 | 11:28 PM
King of NYC
jmkiang is correct. The way the contacts are setup means it doesn't matter which way they are inserted. Some bulbs are like that, not 7443s.
By the way, gcoast is quiet all of a sudden....maybe he realized his mistake.
Old Oct 30, 2008 | 09:53 AM
how do you install switchbacks? I want to get them done but im clueless as to how to install them.
Old Oct 30, 2008 | 10:17 AM
godizus's Avatar
Needs wheels
I had the same problem he states on one side and I simply rotated and re-inserted and my problem was solved.
Old Oct 30, 2008 | 10:49 AM
jmkiang's Avatar
zaino'd
Then you are one of the few that experienced this.
Old Oct 30, 2008 | 11:08 AM
godizus's Avatar
Needs wheels
Yay for me! I'm special!
Old Oct 31, 2008 | 02:24 AM
gcoast213's Avatar
blackac
switchbacks
i contacted autoillumination and they said i needed to get some resistors to sort out the problem. once ive tried it ill let everybody know.
08KBP_VA
Oct 22, 2019 01:55 PM
jterp7
3G MDX (2014-2020)
Feb 3, 2016 08:34 PM
ExcelerateRep
Oct 14, 2015 08:20 AM
kev87a
Sep 26, 2015 02:30 PM
blackwarrior
Sep 26, 2015 09:09 AM
