Strange noise & kick on Startup
I have a 2005 Acura TL, and recently I have started noticing a wierd noise and a small kickback on the Accelerator, it happens after a cold start within the first minute or so. Anyone experienced that? Start your car with radio off etc so you can hear it, reverse the car then accelerate forward slowly, it should happen within a minute or two. Is this a transmission problem or gear box problem?
Try leaving the VSA off and see if it still happens. Does it still happen if VSA is turned on after you have reached the self check point. does VSA also control the rear breaks, or is there a seperate ESP?
strange noise & kick on startup
so is that fixable? i have my TL for less than 1 month and I noticed the same thing and it's really bothering me.
called 2 dealer ship but they said it's normal?? but I don't think so...
what exactly is that thing that's causing this?? anyone know?? help!!!!! Tks.
Moderator Alumnus
This is one of discussions we have had since Day 1... Hope this would be helpful.
Originally Posted by SouthernBoy
...I agree with you that this sound does not appear to be normal (if it were, one would think it would be described in the owner's manual). However, apparently it IS a normal anomoly with the 2004 TL. Here's what the Service Manual says on page 19-44:
Kickback
The pump motor operates when the ABS or VSA is functioning, and the fluid in the reservoir is forced out to the master cylinder, causing kickback at the brake pedal.
Pump Motor
Kickback
Pump Motor
- The pump motor operates when the ABS or VSA is functioning.
- The VSA control unit checks the pump motor operating during initial diagnosis when the vehicle is driven over 10 mph (15 km/h) the first time after the ignition switch is turned ON (II). You may hear the motor operate at this time, but it is normal.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
