Step by step with pictures for removing rear seat
I was thinking of buying Tein SS coilovers and wanted to know if there is a step by step with pictures on how to remove the rear seat.
have you looked in the Garage/DIY section for it?
Just a few bolts on the seat ends and 2 hidden in the middle
iirc the gen3 has a bolt behind the headrest- might allow access to the shock mount bolts just from that
csmeance-southern-other expert-- is that correct?
It's all in the 3G Garage. Here: https://acurazine.com/forums/3g-tl-2004-2008-93/3g-tl-garage-faq-3g-tl-newbies-553554/
D-091: DIY:Front and rear damper/shock spring replacement
https://acurazine.com/forums/car-parts-sale-361/fm-modulators-group-purchase-173827/ - Service Manual Scans
https://acurazine.com/forums/3g-tl-tires-wheels-suspension-97/diy-ht-spec-coilver-install-dummies-any-other-suspension-3g-garage-d-091-a-816065/ - w/Pics and including Rear Seat Removal
F-070: DIY: How to remove the back seats to put the suspension?
https://acurazine.com/forums/showthread.php?t=107568
^And if that wasn't enough...
https://acurazine.com/forums/showthread.php?t=816065
FYI Be careful with the Clips Under the Bottom Rear seat which are located at the Front of the bottom rear seat. I Sorta Broke mines since I didn't know how the hell they came apart. I just pulled and they broke apart so be gentle and figure out how they come apart before pulling then out. I need to go to Acura and order two more sometime soon.
Also another trick is NOT to take out the screws behind the headrests but to simply loosen them a few turns. The seat is designed to slide onto them to make putting it on easier!
^^^that is teh absolute truth.
You can get away with putting the seat back in without any of the center bolts holding down the butt portion. Makes it much easier to access later. Did an install this weekend and was able to even get to the 2 top nuts without removing the rear deck. It was tight, but manageable.
