Start up screen of MID
Old Mar 28, 2004 | 05:12 PM
cutemp's Avatar
Once a while, when the car starts, the upper central console will keep displaying 'Phone', and no CD/XM channel info. The MID screen will display the phone signal and battery only. I can go thur the other MID screens and see the miles and temp with the info button, but then it will go back to the same screen again after few seconds. Is that normal? It is not like an 'in use' screen. I can still use the voice activation and listen to the audio ... Anyone had the same problem?
Old Apr 18, 2004 | 08:22 PM
rets's Avatar
Moderator Alumnus
Yes, when I start my engine, HFL info screen is frequently the first display on MID, which shows my singal strength and battery life. All MID/Navi/Audio features are working. But if I don't hit "talk" and "cancel", this screen will not go away.
Not many ppl have this issue, and the dealer has no clue what's going on. However, this doesn't bother me now.
Old Apr 18, 2004 | 08:30 PM
moreace's Avatar
Anthracite Trend Setter
There is a simple fix. Switch to Verizon and you wont have to worry about the HFL at all
Old Apr 18, 2004 | 08:45 PM
TLGator's Avatar
:lol1:
Old Apr 18, 2004 | 09:11 PM
hoyahenry's Avatar
I have this too. T610/Tmobile if that helps.
You'll also need divine intevention to get the car and the phone to sync up if you start/receive a call before putting the key in the ignition.
So far, I always have to turn the phone off and back on again.
Old Apr 18, 2004 | 09:18 PM
04tlnbppar's Avatar
I have the same problem with S/E T616. This keeps bothering me, but not sure if this is the problem due to the phone or TL...
Old Apr 19, 2004 | 07:29 PM
hoyahenry's Avatar
Thinking about it more, the fact that I cannot turn off Bluetooth using the phone menus ("connection busy") tells me that (even with no call in progress) this is more likely an issue that SE can address.
I think I might give them a call.
Old Apr 19, 2004 | 07:41 PM
hoyahenry's Avatar
"I think I might give them a call."
Ok, that was a waste of time.
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
bearingman07936
Jan 7, 2016 03:22 PM
obert
Dec 14, 2015 11:36 PM
Birdflunuggetz
ILX
Sep 14, 2015 07:00 AM
