Spark plug question
Old Oct 3, 2018 | 08:29 PM
budbudford's Avatar
Spark plug question
My 05 TL just crossed 200k, so time to change those plugs. At what point do the coil packs get changed? Coil packs have never been changed to my knowledge.
Old Oct 4, 2018 | 12:08 AM
WDPanda's Avatar
When you get misfires
Old Oct 4, 2018 | 12:25 AM
budbudford's Avatar
Thanks!
Old Oct 4, 2018 | 07:47 AM
horseshoez's Avatar
Latent car nut
FWIW, the spark plugs are due at 210,000 miles; leave the coils alone unless one fails, then replace just that one.
Old Oct 4, 2018 | 09:52 AM
losiglow's Avatar
Yeah, the coils aren't really a wear item. They either work or they don't. And if you get one that fails, purchase one used, like on eBay. They're all over the place since the J engine is common, and they don't go bad often. Used is way cheaper than new and just as good.
Old Oct 4, 2018 | 10:43 AM
this
Old Oct 4, 2018 | 01:51 PM
nfnsquared's Avatar
Both times that I've pulled my NGK plugs after 105K miles on them, they still had the original gap. These plugs are probably good for 200K+ miles....but spending ~$50 dollars every ~7 years/105K miles is a no brainer....
Old Oct 4, 2018 | 07:35 PM
budbudford's Avatar
This one’s been neglected. I’d bet the plugs haven’t been changed either.
Just did a junkyard run last week. The trunk lid was rusting, and the nav was out. Picked up both for $125. So I’m ready to throw a few TLC bucks into her. Already took care of that nasty rattle which was the timing belt tensioner. So new belt, tensioner, pulley and water pump. The engine is a little loud, so I think the lifters will need attention too.
On deck, plugs, tranny fluid dump, and internal led makeover.
Old Oct 5, 2018 | 08:23 AM
frankjnjr's Avatar
(CURIOUS) " The trunk lid was rusting," Where specifically was the deck lid rusting? Have not seen this issue on 3G TL models in my area!
Old Oct 5, 2018 | 09:41 AM
budbudford's Avatar
If you’re looking at the rear of the car, driver’s side bottom to middle of the lid at the crimp. I’ve never seen this as well and I live in Minnesota with plently of salt and snow. I’m guessing there was some “repair” work done there at some point.
Old Oct 8, 2018 | 09:58 PM
Sgt1411's Avatar
On the NGK website there a few choices for the 2007 3.5L engine in the TLs..just wondering which model members here have had good results with?
Old Oct 9, 2018 | 07:24 AM
Turbonut's Avatar
IZFR6K11
These iridium plugs last an incredible long time as I've seen 150,000 miles and no problems.
Old Oct 9, 2018 | 08:41 AM
90foxnotch's Avatar
Have you started a build thread? Thatd be a fun process to see...Always nice seeing cars getting some TLC. And my car has rust on the quarter that is coming back so I know how you feel. No fun
Old Oct 9, 2018 | 08:28 PM
DMZ's Avatar
DMZ
Head a da Family
More like you need a valve adjustment.
Old Oct 11, 2018 | 07:28 AM
Sgt1411's Avatar
ok thanks, I will grab the IZFR6ZK11
Old Oct 11, 2018 | 03:25 PM
WDPanda's Avatar
You'll be surprised how many people go in for a simple $60 spark plug change and come out with all crappy aftermarket coils and who knows what spark plugs with a whopping $2-500 bill. Some mechanics....
Old Oct 11, 2018 | 03:55 PM
SouthStar019's Avatar
replaced mine with the OE NGK ones and WOW what a difference they made. car only has 100K on it.
Old Oct 11, 2018 | 04:58 PM
horseshoez's Avatar
Latent car nut
What was in there before? The OEM plugs? If yes, I'm having a hard time believing they made any difference at all. I changed out the factory OEM plugs on my J30 equipped Honda Accord at 140,000 miles and they made virtually zero difference in performance, the smoothness of the engine, or the fuel economy.
Old Oct 11, 2018 | 05:00 PM
losiglow's Avatar
I've never noticed a difference with new plugs. Which is sort of disappointing considering they're not a real cheap maintenance item. I think it's because the NGK Iridiums last for-freakin-ever.
Old Oct 12, 2018 | 12:19 AM
had OE NGK but I dont think they have ever been changed. i did notice my idle was much smoother. i hardly notice the engine on when i am idling. before i always felt a slight vibration. very slight. i found it strange also. no oil on the plugs. or any kind of ashy particles. the performance might be psychological. its not my daily so when i do drive it it feels faster.
photog
Oct 15, 2013 11:53 AM
szhosain
Jun 14, 2006 01:15 AM
njzprettyboy
Jul 23, 2004 09:49 AM
Mr Hyde
Feb 5, 2002 08:51 AM
