Side markers and head/taillights
Old Jan 30, 2011 | 04:40 AM
kore's Avatar
5th Gear
Arrow Side markers and head/taillights
so i looked around on the fourms for a bit but couldnt find anything. Im looking to replace my rear (red) side markers for grey ones or tinted ones... so that they dont look so ugly ; ). anyone know where i go to grab something like this?
also.... whats the best way to go about tinting my headlights and tails? (trying to make em' darker). do i need to buy all new head/and tails or what?
thx in advance
05 TL ABP/
Old Jan 30, 2011 | 07:01 AM
tufino1128's Avatar
Search on ebay you could find the side markers smoked like the type s and they have a special i think it's 200 dollars for all 4 side markers and type s taillights and you could find clear headlights too
Old Jan 30, 2011 | 08:36 AM
Depo and OEM.
if you search ebay, you'll come across these two.
i decided to go the DEPO route for my side markers. they had all 4 smoked sides for about 70 dollars.
Just the rear type-s OEM's were 90.
we also have a member on here by the name of AckTL05. He does custom heads and tails.
I would never tint my heads or tails, we're not in 1999 any more.
Search around this forum, many times people sell things on the black market.
Old Jan 30, 2011 | 08:58 AM
6SPD_TWINZ's Avatar
2004 Aspec TL
thx in advance
05 TL ABP/
Get them from this site
http://www.uniquestyleracing.com/20actlclorsm.html
Old Jan 30, 2011 | 03:22 PM
kore's Avatar
5th Gear
Depo and OEM.
what are you talking about when u say the DEPO?
Old Jan 30, 2011 | 03:28 PM
kore's Avatar
5th Gear
also... 6spd-Twinz, i took a look at that site. that looks pretty sweet for that deal, is that website legit though? can u or someone vouch for it?
if so ill probably go for those
Old Jan 30, 2011 | 07:30 PM
that website is one of our vendors. its legit.
Old Jan 30, 2011 | 08:07 PM
AckTL05's Avatar
Former Sponsor
If you wanted to go cheaper I can niteshade/tint your rear side markers or brand new type s rear ones would run $110 shipped.
I can black out your headlights and make you custom tail lights. I can color match them as well.
Old Jan 31, 2011 | 01:00 PM
Sir Drake's Avatar
Depo and OEM.
Have you had any problems with moisture getting in your DEPO side markers?
Old Jan 31, 2011 | 01:02 PM
theres not away for moisture to get into.
its a sealed unit much like OEM.
I did have fitment issues but was easily solved with A) Time B) Sandpaper.
Old Jan 31, 2011 | 01:08 PM
stvtec's Avatar
'06 WDP TL 6MT
Do the clear crystal ones from uniquestyle look and fit "right"? You know what I mean, sometimes non-OEM parts just have that "not quite right" look/feel.
Old Jan 31, 2011 | 01:09 PM
Sir Drake's Avatar
What part did you have to trim down? Also Do you know if the type-s are a direct fitment(even though they cost more), no mods/sanding needed? What type of tail lights do you have as well?
Old Jan 31, 2011 | 01:10 PM
not sure, i would never pick up the clear ones!
they're ugly!!!!!!
Old Jan 31, 2011 | 01:14 PM
With OEM and DEPO, you might get a slight fitment issue.
How is the sidemarker held in place? a hole in the body of the car and the side marker utilizes a slightly lager plastic clips. Sometimes the plastic clips are a little to large and you just have to round off/shave off some. when you're hands on you'll realize which sides have to be shaved enough for clearance.
Old Jan 31, 2011 | 01:15 PM
DEPO side markers with stock tails.
Old Jan 31, 2011 | 01:20 PM
Sir Drake's Avatar
Sweet TL, thanks alot...also I think you have the "moleskin" for window tint...never heard of it...why is it a must have?
Old Jan 31, 2011 | 01:22 PM
stvtec's Avatar
'06 WDP TL 6MT
they're ugly!!!!!!
Hm I thought they might be ok on WDP. And also I'm cheap and I don't get why its $20 more for the smoked ones. I could always buy the clear ones and then smoke them if I don't like the clear look... or just bend over and pay the $20 extra.
Old Jan 31, 2011 | 01:29 PM
inside the door panel is a trim, i suppose this trim helps keep dirt away when then window slides up and down.
ironically, this trim traps the dirt. When you lower your freshly tinted windows, the trapped dirt scratches your tint. there will be long vertical scratch marks.
My back window has a scratch.....
all i did was apply some felt to this trim. essentially the same thing as mole skin.
hmmmm they might look good on a WDP, im not sure. I knew the direction that I wanted to take my silver color and the clear sidemarkers didnt do it for me.
Old Jan 31, 2011 | 01:30 PM
stvtec's Avatar
'06 WDP TL 6MT
Yeah the smoked ones look really good in your pic. Clear would definitely look odd on silver.
Old Jan 31, 2011 | 01:35 PM
Sir Drake's Avatar
Did you stick with the stock bulbs for the sidemarkers? On the uniquleystyleracing website they have with amber leds and white leds...
Old Jan 31, 2011 | 01:36 PM
Sir Drake's Avatar
dont think the white leds would be legal.
Old Jan 31, 2011 | 01:38 PM
Thank you, sir!
Old Jan 31, 2011 | 02:21 PM
dwb993's Avatar
It depends on the laws in your state. Many states allow white sidemarkers and parking lights but require amber flashers. Switchback LEDs meet this requirement, although they may not pass inspection as they are not DOT approved (I don't think any non-OEM LED exterior lights are DOT approved).
Old Jan 31, 2011 | 02:24 PM
Phambam12's Avatar
Phmbm12
how do you take out the sidemarkers anyway?
i heard it was possible to just pop em off from the outside but im not gonna risk breaking mine testing it
Old Jan 31, 2011 | 02:28 PM
A larger backing clip into a small hole. so you would have to push from behind the marker to get it out.
see the square? there are two clips that push against the hole.
Old Apr 3, 2011 | 12:28 AM
AnthonyTL-S's Avatar
is it possible to change the side markers led light inside?
Old Apr 3, 2011 | 02:27 AM
AckTL05's Avatar
Former Sponsor
Yes, like this:
https://acurazine.com/forums/3g-tl-2004-2008-93/custom-side-markers-teaser-thread-800333/
Old Apr 3, 2011 | 08:52 AM
SSM4DR's Avatar
Justinspace, those smoked sidemarkers are looking good . Thanks for the tips with sanding paper as well. I just placed my order yesterday .
Edit: I ordered mines from uniquestyle.
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
blacktsxwagon
Oct 27, 2015 10:12 PM
Dman00tl
2G TL Photograph Gallery
Sep 25, 2015 10:34 AM
