Seat problem question???
Old Nov 9, 2006 | 01:18 PM
MrKinn's Avatar
i did a search for seats and i get about 5 million. so i know i read something awhile back about this but
i have a 04 TL My driver side seat sometimes pops and makes nosies when i move around in it. Has anyone had this problem and what canbe done about it?? Will they warrenty it and give me a new seat??
Old Nov 9, 2006 | 02:26 PM
KJSmitty's Avatar
WDP Director of R & D
My "seat" pops and makes strange noises as well... Though it's usually after I have eaten too much etc....
Seriously though, I have an 04 as well and so far no strange noises from the seats. I wonder if you have a worn out seat track or worm screw (adjuster etc.). Do your power seat functions get used often - as in multiple drivers etc.?
My guess is something is worn or bad within the seat track/frame mount. They will probably remove the seat and just replace the frame/effected track area. Not the entire seat.
Good luck
Old Nov 9, 2006 | 02:37 PM
MrKinn's Avatar
Good luck
I need to desribe this better... Its right in the middle of my back.. when i put less presure on the back of the seat.. or pull myself away from my seat it will pop i lean back i hear if and feel it going in. pull away again pop... Its like the metal or soemthing inside the seat is flexing .... Its not the track or anything close to that.. Just makes popping noise when i move or adjust my back!!!
thanks for chiming in KJ
Old Nov 9, 2006 | 02:51 PM
Ron A's Avatar
Administrator
There's a lumbar support in the driver's seat back, controlled by a rocker switch at the rear of the bottom left side of the seat. Try adjusting that and see if it helps. It may be broken or loose or something.
Old Nov 9, 2006 | 07:15 PM
Fulani has a TL's Avatar
WAITT!!!! is it only the 2004 model that has the lumbar support? or do 04-06 models have them? I have an 06 and have never seen that button, yet i never tried looking for it
Old Nov 9, 2006 | 07:44 PM
Ron A's Avatar
Administrator
All 3G TL's should have it. It's right behind the seat adjuster switch.
Old Nov 9, 2006 | 08:19 PM
MrKinn's Avatar
I will tweek it some and see if it works.... if its still making the noise do you think this owuld cover under warrenty???
Old Nov 10, 2006 | 12:50 AM
Xpditor's Avatar
Old Nov 10, 2006 | 07:45 AM
Ron A's Avatar
Administrator
Warranty is 4 years/50,000 miles, so if you are under both of these it will be covered.
Old Nov 10, 2006 | 07:48 AM
MrKinn's Avatar
Well im under the mileage so i will call them and try to describe this the best i can... i will post an update on what they say.. Thanks guys
rockyboy
Aug 4, 2024 10:35 AM
bailey24
Nov 21, 2015 08:43 PM
d.lim
Sep 15, 2015 08:54 PM
jfman55
Sep 5, 2015 02:55 PM
kareshi
Sep 3, 2015 03:38 PM
