Seat heater
Old Nov 17, 2017 | 11:35 PM
typesdad's Avatar
Seat heater
Do the seat heaters warm up the back only or the bottom?
Old Nov 18, 2017 | 12:47 AM
Will Y.'s Avatar
Registered but harmless
Only the bottom for the passenger seat; but the heaters warm both the bottom and backrest of the driver's seat.
Welcome to AZ.
Old Nov 18, 2017 | 12:58 AM
typesdad's Avatar
Huh. The bottom of the driver's seat doesn't seem to heat up, only the back. What could be the problem?
Old Nov 18, 2017 | 03:25 AM
mariusz439's Avatar
Hardly impossible as bottom and back compose one electrical circuit.
Old Nov 18, 2017 | 06:58 AM
04WDPSeDaN's Avatar
iWhine S/C 6MT TL
The heat pad element, is no longer good. You can buy one at your dealership or on line (Any oem site). Luckily, the drivers seat bottom is the easier one to replace. You still need to remove the leather to replace the element.
Old Nov 19, 2017 | 05:15 AM
mariusz439's Avatar
It is not difficult to repair it on your own on the other hand. I did it one month ago and fixed all 3 mates. You just need soldering iron, multimeter and and obout 5cm of wire for each circuit brake.
The key question is do you feel you can do it.
Old Nov 19, 2017 | 03:14 PM
typesdad's Avatar
How long did it take you to repair one? I'm willing to do the repair if it doesn't take more than a day's work. I'm OK with a soldering iron, multimeter and I've wires. Do I need to cut the leather?
Old Nov 20, 2017 | 03:21 AM
mariusz439's Avatar
Hard to say how long did it take as I did it in the evenings and restored the leather.
Seats removal and disassemble is easy and I estimate it on half hour. The pain is to remove leather covers and put them back when you reusing rings tightening the covers to frame. If it would be your first time, I suppose you should manage to proceed in 6-7 hours.
gobears34
May 27, 2009 11:49 PM
