Resistor Installation for LED Switchbacks
Old Sep 6, 2010 | 12:47 PM
h4qq's Avatar
hey AZ, quick question on the resistor installation:
could anyone give me a detailed (but simple) explanation of the resistor installation? I've seen the DIY on here and it just says "connect" the resistor to the ground and turn wire, but how exactly does it "connect"? Do I have to strip down the wires, take out the wire from the headlight connectors and run it through the blue splicers? Also the left headlight seems to have 2 red wires and one black wire... I have the V-LED switchbacks and resistors.
thanks everyone
Old Sep 6, 2010 | 01:09 PM
AckTL05's Avatar
Former Sponsor
Do it from the back. Located the rear turn signal bulb and connect one side of the resistors with the blue tap to one wire and the other side of the resistors to the other wire with the blue tap.
Old Sep 6, 2010 | 01:15 PM
h4qq's Avatar
oh it doesn't matter if it's done in the front or back? interesting.
but again though, you say "connect one side of the resistors" - how exactly is that done? lol
Old Sep 6, 2010 | 01:59 PM
P1zzaman's Avatar
Originally Posted by AckTL05
Do it from the back.....
Rogues do it from the back
Old Sep 6, 2010 | 05:21 PM
h4qq's Avatar
my question is more just about how to get the wire from the headlight connectors into the blue splicer thingy
Old Sep 6, 2010 | 07:42 PM
navarretg's Avatar
2004 Acura TL
I had a member on here do mine. He told me when they are properly installed the resistor will warm up fast, thats a good indication you have done the job correct!
Old Sep 6, 2010 | 08:17 PM
h4qq's Avatar
anyone? gotta get this done by tonight, the TL is sitting in the garage bumperless
Old Sep 6, 2010 | 09:06 PM
DeathMetal's Avatar
Fearless DIY Guy
The blue clip will have two 'channels' - one channel will be open on both ends, the other closed on one end. Insert the resistor wire into the closed end. Insert the BLINKER wire on the headlight (Blue w/ red stripe on driver, white on passenger, IIRC), and clamp down. Repeat this process and connect the other clip and resistor to the ground wire...so your resistor goes BLACK ---> RESISTOR ---> BLUE/RED -or- WHITE
Old Sep 7, 2010 | 12:55 AM
Bearcat94's Avatar
AZ Community Team
Resistor install for led blinkers pics.... Linky
Old Sep 7, 2010 | 02:22 AM
h4qq's Avatar
thanks for the responses guys
okay so I did it, pretty simple and clear, however; when I try my turn signal, the inboard dash just displays a constant Left turn signal (I have only installed it on the left signal so far, right one is still the normal bulb), and the LED doesn't turn on at all, any help?
EDIT: nevermind, switched the LED around and it works GREAT, thanks for everyone's help
Feb 25, 2020 09:57 AM
jblessing
Aug 8, 2018 09:43 PM
baowheezy
Sep 22, 2015 09:03 PM
Greengecko
Sep 16, 2015 08:19 PM
ghuns
Sep 16, 2015 04:26 PM
