Removing trunk light?
Old Apr 12, 2008 | 04:22 AM
Sondinh's Avatar
TEAM_SONIC
I went to look for threads on changing the bulb in the trunk. Does anyone knows what to use to open the plastic cover in the trunk light?
Old Apr 12, 2008 | 08:09 AM
jumbosizeme79's Avatar
aTLien
get a flat head screw driver and muscle it out, its simple. i thought it was impossible bc i thought i would break the plastic, but nope just put some muscle into it
Old Apr 12, 2008 | 09:50 AM
Cdat's Avatar
Slow Paper> No Paper
Had the same problem took forever for me because I thought I was gonna break it. Just use a little M.A.N. and you'll get it.
Old Apr 12, 2008 | 11:15 AM
Ron A's Avatar
Administrator
It's so easy I never bothered to post the scan before, but here it is anyway.
Old Apr 13, 2008 | 05:50 PM
LaCostaRacer's Avatar
I just did this mod. today You'll find that you can pop out the light 'easily' by jamming a thin jewelry-like screwdriver in the passenger side portion of the light (portion on lens opposite of actual bulb location). Just jam the screwdriver in about 1/2 inch and wiggle it around to release a tab that holds this light in.
Another bulb removal tip is to wrap some non-slip rubber around the light and use some pliers or vise-grips to wiggle the light out. I tried this mod a few months ago and thought I was going to break the light too, so you're not alone. Now with this knowledge I'll work on the glovebox that has the same light.
Many thanks to Knertified's tip back on 5-19-07. It's amazing what search will find since the answer was there.
mada51589
Jan 9, 2025 04:40 PM
cycdaniel
Dec 17, 2019 10:58 AM
handsom-hustla
Nov 13, 2015 05:04 PM
PortlandRL
Sep 14, 2015 12:01 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
